Results 1 to 10 of 10
    May 2009
    Mga bossing,
    Storytelling muna ako ha.
    Before servicing: brake pedal ko e mejo pumupulso pero negligible.kung talagang "observant ang paa ko" e napapansin kong pumupulso. i repeat, negligible sa pakiramdam.hehe
    After the servicing: tumindi na ang pagpulso. halos sasabay na rin ang puso ko dahil kumakapit then nawawala then kakapit and so on ang preno.
    what could be the problem? nakakailan nako sa adjustment sa brake drum pero hindi matanggal ang pagpulso.
    eto ginawa sa pipip ko. nga pala pipip ko e mighty max na 4d56t auto. yung dati pa rin ang brake lines.
    1. reface disc rotor (left front lang kasi ok p ung right front)
    2. palit ng flexi hoses kasi may tagas na
    3. pinantay rin ung brake pads sa calipers
    4. linis preno sa harap at likod.
    5. palit rubber cap at boot sa left rear.
    6. sangkatutak na "bleeding operation"
    TULONG PO!
    Have your other rotor resurfaced also it could be uneven which is causing the pulsing. What do you mean by number 3? Did they put new pads or just used the same old pads?
    May 2009
    regarding no. 3, yung brake pad kasi sumunod na sa contour ng disc rotor kaya pinantay ko boss. antagal nga ng pagliliha ko e.kapagod.cguro nga ung kabilang disc rotor. nxt time na lang at naubos na pera. by next payday uli.huhu. ang sabi naman ng kakilala kong mekaniko e baka raw hindi na perfect circle ung brake drum sa likod. ganun ba kadali ma-"oblong" ang brake drum? i think hinde. kasi ininspect ko wala naman. salamat sa reply boss
    ganyan dati pajero namin. have it resurfaced both sides left and right pati yun inner and outer disc surface.
    Quote Originally Posted by miked View Post
    Ok. I have never done that with brake pads, usually if I have it resurfaced I put new pads and not reuse the pads. If you are reusing the pads it could be the pads causing it also since you mentioned having the pulsation get worst.
    May 2009
    cge mga boss,
    noted lahat. subject to availability of funds pa ang palit pads at rotor. i'm planning din kasi na bumili ng disc rotor kasi manipis na yung isang side sa left front. sa surplusan na lng siguro. ok lang naman na isang disc rotor palitan di ba mga boss? salamat sa mga impormasyon
    Jul 2003
    there could be a problem with the mastevac/hydrovac. Check the vacuum lines and the mastervac for proper operation. Did the mechanic who serviced the brakes removes the brake master cylinder from the hydrovac?
    cge mga boss,
    Save the money and change it as a pair instead of just one.
Pumupulso pa rin ang preno ko!help!!!
