Results 1 to 20 of 41
    Aug 2019
    So I recently brought a new car and it was released from the casa around 2 weeks ago.
    Although I noticed that after a full stop brake, whenever I depress the brake, it makes a groaning sound from the front side of the car. Not all the time, just sometimes. Like.. 30% of the time.
    The front brakes are ventilated disc type. The transmission is CVT (if that matters).
    EDIT: Sounds like this, check 1:14 of the vid: Weird noise when pushing and letting off the brake pedal when at stops - YouTube
    Is this normal? TIA.
    abs light on? try hard brakinf?
    Aug 2019
    ABS light does not come on at any time. Manual says it only comes on when there is a problem with ABS.
    Aug 2019
    It kind of sounds similar to this one, around the 1:13 mark:
    groaning? or grinding sound?
    Aug 2019
    Maybe grinding? I'm not really sure how to describe the sound. It's like the sound at this video around 1:14 mark: Weird noise when pushing and letting off the brake pedal when at stops - YouTube
    Quote Originally Posted by gomezgomez View Post
    my wild guess,
    something is loose.
    perhaps the brake caliper assembly.
    or the wheel lug nuts.
    or, your bearings are broken.
    have it lifted, and examine your suspension and steering components.
    If it sounds abnormal then bring it back to the dealer, they could have skipped some QI procedures when the vehicle was released. Also, suspension and alignment warranties are usually valid for 15days only-they are treated as consumables.
    Baka since bago pa hinde pa nag set yun brakes. Hinde yata ginagamit eh. [emoji1]
    Aug 2019
    Grabe gamit na gamit nga eh hahaha. Nasa 400+ na yata odometer. Di lang nagagamit pag coding. Hahaha
    Observe ko muna hanggang 1K. Baka nga nag a adapt ba yung pads sa disc. Ang medyo niwoworry ko lang baka mawalan ako ng preno bigla or something. Paranoid hahaha. Di naman magkakaganun no?
    naalala ko yun bendix rotor ko noon, nakalagay no hard braking for 300km
    Dec 2009
    ^tama
Is it normal to hear a groaning sound when depressing brakes?
