Originally Posted by
boy astig
Sir, how long has it been since you last changed your PS fluid? Kung more than 3 years na, suggest you do it asap. Kung nagpalit ka na ng ball joints at yung nilagay mo ay may fittings, magpa greasing ka na rin. These will do a lot of help and hopefully solve your problem. If orig pa, palitan mo na. I agree with mbeige. Kung lumalangitngit yung belt mo or may times na malambot-matigas-malambot-matigas yung steering mo, signs of belt slippage na yan. Mbeige said it correctly, it may ok upon inspection. Check the underside of the belt (the one that gets into contact with the pulley). Malamang puro crack na yan.
Also, check mo yung gearbox mo for leaks.
I had a problem with my spindle some years back. Bumaluktot dahil bumigay yung wheel bearing ko, right side. Almost two weeks ako tumatakbo na halos 45 degrees yung right tire ko. Newbie lang kasi ako nun sa motoring world kya d naagapan agad. Maraming machine shop dyan along alabang zapote road that can help you with that.
HTH
