Results 1 to 5 of 5
    Mar 2003
    my power steering went out (kanina, lintek! lakas pa naman ng ulan) and my battery & brake light turned on in the dash. So I pulled over, pag-bukas ko ng hood..Yikes!! I noticed my belt was gone!! connecting to my alternator and power steering pump..
    tapos nung napalitan na yung belt.(papauwi na ako) may squealing sound ako naririnig at medyo bumigat yung manibela. ano kaya ang problema nito?
    1 Power Steering Pump? << sana hindi ito..
    2 Power Steering fluid leak? (check ko kanina, wala naman leak..kaya lang di ko nakita yung nasa ilalim))
    3 Nadamay yung PS pulley? (pumulupot kasi yung belt sa pulley)
    or
    4 Kulang lang sa higpit yung belt? << sana may koneksyon ito sa problema ko. para walang gastos!
    Mar 2007
    sir check mo reservior if you're loosing fluid level, theres a leak somewhere not visible. might be some worn parts or internal leak in the pump, repair kit lang replace. batt will come out bec alt stop rotating while engine is running. squeeking sound caused by loose belt tension, use the rule of thumb. better have it checked by a reliable mechanic to avoid big damage, something might be wearing out. IMO
    Sep 2006
    check and replace the ps fluid and purge the air.
    Jul 2006
    Hens,
    Kapag bumigat yung feeling sa manibela, maluwag or dumudulas lang yung belt. Dati nabasa yung belt ng TDT namin, maluwag pala. Parang lumalaban yung manibela when I tried turning the wheel. Baka since emergency fix yan, hindi lang nahigpitan nang maigi.
    Check mo rin hood mo kung may dent dahil sa belt...anong car ba ito? Tsk tsk...baka naman kasi masyado mabilis para sa belt hehe...
    Nov 2003
    dumudulas lang belt nyan. have it retightened and it should be ok.
power steering problem...
