Results 1 to 7 of 7
- Apr 2006
- 40
May 9th, 2006 05:05 PM #195 honda civic esi manual transmission * 95th km
...i have this steering problem.when traveling in a smooth straight road, my steering seems to move leftward.it hardly maintains a stable direction when i free-hand it..
also one time, i accidentally cruised to a bumpy road and very much worried if this has affected my underchassis components...any comments?
thanks!
May 9th, 2006 05:46 PM #2
pa check mo po agad sa talyer. or maybe need wheel alightment.
regarding your underchassis, you can check kung may nasira, ma-feel mo naman yun kapag may kalampag ang ilalim mo, or something wrong pagnagdrive ka.
May 9th, 2006 08:23 PM #3
wheel alignment. or busted ball joints. or damaged tie rod ends or rack ends.
when was the last replacement of these parts? these things go with high mileage. let me guess.. the uncertain steering gets worse at high speeds? time to replace some ball joints and tie rod ends probably...
- Oct 2005
- 177
May 9th, 2006 08:28 PM #4Check mo muna yung whell alignment.. cheapest kasi to eh.. tapos pag nde nakuha sa alignment..pabaklas mo na para makita kung saan sira..
Wag ka na mag risk dyan..delikado eh..lalo na sa high speeds..
May 9th, 2006 10:13 PM #5
same thing happened to my ride. i had it aligned pero at high speeds it was still tracking to the right. gumastos pa ako. finally, i had the balljoints and tierod checked and sure enough the balljoints were loose. you can see the boots already torn and if you pull it back and forth it was already shaking. according to the mechanic, buti na lang di kumalas kundi aksidente ako.
May 15th, 2006 09:19 PM #6Originally Posted by BlueJazz
...o di ba, eliminating all possible causes!
Toyota is my choice
- Aug 2005
- 2,063
Thank you!
