Results 1 to 10 of 22
November 27th, 2006 11:09 AM #1
sir,
ask ko lang kung magkano ang isa ng set na ito?
for 96 vti
comparison price po sana OEM at replacement lang.
November 27th, 2006 02:05 PM #2
Not sure about Honda.
But an OEM Gearbox Kit for a Suzuki is * 5,032.04 and the OEM PS Pump Seal Set is * 1,142.49. This will give you at least some idea.
Baka naman seal set lang ang kailangan mo.
The estimated labor to install both kits is Php2000.00
- May 2006
- 141
November 27th, 2006 02:47 PM #3Power steering Vane Pump Kit around 1200-1400 OEM..kabibili ko lang one month ago I used it for my VTI 2000
- Jul 2003
- 41
November 27th, 2006 09:24 PM #4kakabili ko lang kanina OEM kaso pang city 98 nasa P1,015. less 10% discount P914.
November 28th, 2006 09:03 AM #5
tnx guys. bibili rin kasi me nito.
may tagas kasi eh. siguro more or less. mga 1500.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 29th, 2006 12:16 AM #6for ps pump repairs only use oem parts. they fit so much better. also replace the bearing while you're at it. price for honda's is separate from the kit.
November 29th, 2006 02:19 PM #7
di pa po pala kasama yung bearing sa "Power Steering Overhauling repair kit"
tnx po. mag-canvass na rin ako ng bearing.
- Nov 2003
- 3,849
January 31st, 2007 06:27 PM #9
yun akin may tagas nun inangat shell nun nagpachange oil ako, bili daw ako ng power steering repair ganun din sabi nun mekaniko nun nagpa radiator overhaul ako. Yun repair kit ng big body gli na 3,600 daw. Sabi ng kaibigan ko, paunderwash ko tapos obserbahan kung tagas ulit tapos baka hose lang, tapos nun nagpachange ako timing belt, nakita hose lang daw yun tagas, ipatiningin ko sa mga hydraulic hoses shop kaya daw nila gawin. pinatingin ko naman malapit sa amin, sa hose daw kapag sagad sumisirit yun fluid pero di ko nakita kasi ako may hawak ng manibela. pinapalitan ko ng hose, nawala na yun madaming tagas, meron konting konti, mga tablespoon na lang.
BANNED BANNED BANNED
- Jul 2003
- 2,267
January 31st, 2007 10:35 PM #10brus, pakilinawan nga ako.
pag sinabing power steering overhauling kit, ito ba ay para sa PS pump???
how about yung sa ibabang part ng steering. yung may rack and pinion ba yun??? anu tawag sa kit na yun???
nagpalit na din kami nun ng bearing at seals sa PS pump kasi may tunog na yung bearing. mejo mahal nga siya (93 esi).
ngayon naman, mejo sinisilip ko yung sa ilalim kung san directly connected ang manibela. mejo nauubos kasi ang fluid kaya inabangan ko na. in the mean time, yung hoses muna ang check tapos lagay nung leak stopper. :D
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
