Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Feb 2007
    Mga Sirs, I have a problem with my power steering, lancer 95 car ko. Di ba pag power steering, even if the engine is turned-off, the steering wheel should be manageable, as in malambot dapat. But I noticed that once nag park nako, yung steering wheel ko is as hard as the usual pawis steering. What seems to be the problem? Thanks in advance!
    Jan 2003
    Red07,
    you got he wrong info, when you turn off the engine your steering pump also stops, so no fluid is pumped to the steering rack thus making turning the wheel hard.
    Feb 2007
    I also go a reply from galactus in the one of the threads where I posted the same inquiry. So it's normal pala talaga. I was just wondering because we used to have a box type lancer na power steering. Kapag naka off yung engine malambot naman yung steering wheel.
    Feb 2007
    Mga sirs, correction po, kapag naka stop pala matigas even if the engine is still running. My wife just texted me and informed me what she just experienced this morning.
    Last edited by red07; June 28th, 2007 at 10:08 AM. Reason: redundant, wrong spelling
    Jan 2003
    Quote Originally Posted by red07 View Post
    baka maluwag na belts, or baka very low na power steering fluid. also have them chech the tires baka malambot
    Feb 2007
    maximum level naman yung fluid. baka nga belt. thanks po!
    hehehe!!! sir, pag turned off po talagang matigas ang steering wheels ng pawis steering. pag engine on na po saka pa lang lalambot.
  8. #8
    pag standstill, medyo mabigat ang pwr steering, pero steerable kahit 1/2 hand, pero try moving, kahit pinkie lang kaya paikutin..
    pag patay, at standstill, buno yan... take into consideration ang lapad ng gulong mo, total surfaced contact ng gulong sa road x 2!
    baka kaya magaan ang box-type kahit patay makina baka maliit at makitid lang ang gulong
    ps: indication ng maluwag na belt is pag sinagad mo iirit yun! may leak ba? or you see your rubbur-boots na parang may langis sa loob?
    Feb 2007
    Always Yummy, Tama, umiirit nga kapag sinasagad yung steering. 14 din size nung sa box type same nung sa lancer namin ngayon. Saan makikita yung rubber boots? Thanks!
    Jul 2006
    Quote Originally Posted by alwayz_yummy View Post
    hmmm ask ko lang po sir, diba sagad na yung steering mo kaya parang
    sumisirit? normal lang to db? o sign ng maluwag na belt?
    saken kasi ganito pero ok naman yung ikot ko malambot pero kapag
    steady tapos iikot mo, umuugong lang. pero malambot naman.
Power Steering na Pawis Steering
