we'll see hehe...
theveed, how do you apply this ba? is it poured in the reservoir? my leak rin ps ko, but di naman gano kalakas like every 5 days it would be low. sakin siguro, level would be low after 2-3weeks. Evident ung leak sa fittings... habang ipon pa ng pang repair kit, magandang corrective action yan. Thanks
been using cyclo psf for about 4 months now. it really works. there is another product by castrol. not sure if it has a stop leak action.
Ako naman I tried Morey's Power Steering Conditioner as per Mr. Claro of Cruven. It's been over a month now and the leak has been reduced. I just can't fully recommend it yet until there are no more leaks. Price is around 700.
ako gamit ko cyclo power steering stop leak, 4 mos already have passed, wala na akong makitang tagas nun main hose ko. nawala din yun ugong at lumambot steering kahit bagong start.
pre,Originally Posted by theveed
wait for feedback next week. email ko na supplier ko. indent order pwede. according to them, wala daw meron dito sa pinas. try nila import from lucas...
mga bossing ito lang kailangan nyo; since maliit lang application nyan pwede hati hati nalang kyo kasi by (ml) lang halo nyo.
DESCRIPTION
Is designed to condition, lubricate and protect seals in all types of equipment. It protects against seal deterioration and costly machinery downtime, in the process saving operational costs. It is safe to apply, is non-toxic and non-flammable and lubricates seals with no adverse effects.
CHARACTERISTICS
Effective Lubrication
The deterioration of seals (When seals age, they dry out and crack, resulting in fluid loss) is a major cause of machinery breakdown and malfunction. Some seals are known to deteriorate even before they are installed. Therefore, seals must be lubricated regularly to prevent their deterioration and drying, not only stops the leak and fluid loss in seals, but prevent these seals from deteriorating further. Moreover, stops squeals in power steering units.
Preventive Maintenance
Replacing a seal is costly and troublesome: the transmission must be removed and disassembled. Cuts all that labour and downtime expenses. It lubricates, protects and conditions seals, thus prolonging their life and keeping them free from problems.
Safe Application
It is non-toxic, non-combustible and non-fuming. It contains no petroleum, no harmful chlorides or solvents. This prevents both chloride-induced corrosion and solvent-spongy seals. Solvent or chloride-based additives either make the seal too soft or attack metal and rubber parts due to acid formation.
Economical
It needs to be applied only once every 16,000 km (10,000) miles) or at every transmission change. It only requires about 180 ml for a standard size automatic transmission.
theveed... inubos mo ba yung isang bote???
nakabili ako sa concorde megamall.
may stop leak products din pala sila para sa cooling system & engine. mukhang ok ito ha.
M2: Less than half nagamit ko kasi may ATF pa konti yung reservoir nung ginamit ko.
1 week na di padin ako nagbabawas ng ATF hehehe AYUSH!
Sa cooling system mas duda ako kasi may solid particles sya talaga eh, although I've used the STP one before and ok naman, but di nakayanan ng tagas sa water pump ng benz ko.
Up ko lang ito. Sir theveed, ano feedback sa Cyclo Power Steering Stop Leak? Effective nga ba?
Ayus 'to ah, ma-try nga yang Cyclo na yan, mura pa!![]()
Paging brader 'Theveed': Any follow-up feedback pare? Ano na progress? Tnx!
