how much for camber/wheel alignment? any recommended shop?
For camber correction and alignment it depends on each vehicle brand. Ranges from 1,000 to 3,000. Some even charges 7,000 and up. Iba-iba po kasi ang linkage ng bawat modelo ng sasakyan.
You may also want to check the toe in or out alignment and caster alignment.
Yung sa Gen1 PAJ ko CAMBER and align cost me 1300. Pero ang bilis lang ginawa 30 minutes. Mas mahirap yata yung sa mga kotse na naka McPherson sa harap
Sir Chieffy recommended me to Pro Wheels at Pasig. Wheel alignment for a sedan is only P500.
Marcos Hway Servitek's alignment would cost P1,400 for 4-wheel camber, less if you onbly need Wheel alignment.
Sa Tie-rod Man (P Ocampo near Pasong Tamo), P1400 din ang 4-wheel camber. - pwede nga daw sa P1k kung walang resibo (kaya lang pano ang warranty?) P400 for Wheel alignment, 4-wheels.
Front wheel camber daw is Php 800.00 sabi ni Djerms. Yung toe-in toe-out is Php 450.00 naman daw.
Pero these are prices for trucks and SUV's. Mahal ang sa kotse.
teka tuwing kelan ba dapat ginagawa ang wheel camber and alignment? Kasama ba sa periodic maintenance ito? Ako kasi I just do this kung may papalitang parts sa suspension ko.
Yung steering ko kasi ngayon parang maluwag na..may play na kung baga. Will this be corrected kung magpa-align ako? Considering that my suspension parts are all A-ok of course..
boybi,
Ewan ko nga ba. Kaya ayoko na ng kotse. Ang mahal ng parts at services...
Djerms,
Ginagawa lang ito kung may kabig or uneven tire wear (na hindi due to wrong tire pressure).
Kung may maluwag, malamang may faulty part. Alignment is just concerned with keeping your vehicle tracking straight. Yung luwag at higpit, hindi na niya sakop yun.
1000 lang pa camber and wheel alignment ko doon sa Petron in front of Broadway Centrum. malapit kasi doon ang pagawaan ko ng steering (Kalampag specialist), Velocity Motors in front of Caltex... bago pa dumating sa Broadway pag galing kang SM Centerpoint along Aurora Blvd. since Velocity Motors have no lifter, kaya doon pinadadala sa Petron for wheel alignment and camber pagkatapos nila ayusin steering.
Front wheel alignment sa Wheelers inabot ng 300. Kaso toe-in and out lang ang pwedeng gawin sa akin. Baka tumaas ang price pag may camber and castor adjustment.
sa alabang-lp area may servitek and rapide... san kaya mas magaling?
kakalipat ko lang kasi wala akong alam sa mga shops dun
Try mo sa Motorcraft sa Banawe. P250 for toe alignment. P600 for toe and camber/caster. This where I have my Zuks alignment done.
last time i went there, di daw sila nag-align, sira yung gamit nila, tapat ng mcs.
around feb.
