Results 1 to 10 of 27
February 14th, 2004 01:23 PM #2
For camber correction and alignment it depends on each vehicle brand. Ranges from 1,000 to 3,000. Some even charges 7,000 and up. Iba-iba po kasi ang linkage ng bawat modelo ng sasakyan.
You may also want to check the toe in or out alignment and caster alignment.
February 14th, 2004 02:06 PM #3
Yung sa Gen1 PAJ ko CAMBER and align cost me 1300. Pero ang bilis lang ginawa 30 minutes. Mas mahirap yata yung sa mga kotse na naka McPherson sa harap
February 15th, 2004 09:28 AM #5
Sir Chieffy recommended me to Pro Wheels at Pasig. Wheel alignment for a sedan is only P500.
February 15th, 2004 09:52 AM #7
Marcos Hway Servitek's alignment would cost P1,400 for 4-wheel camber, less if you onbly need Wheel alignment.
Sa Tie-rod Man (P Ocampo near Pasong Tamo), P1400 din ang 4-wheel camber. - pwede nga daw sa P1k kung walang resibo (kaya lang pano ang warranty?) P400 for Wheel alignment, 4-wheels.
February 15th, 2004 12:55 PM #8
Front wheel camber daw is Php 800.00 sabi ni Djerms. Yung toe-in toe-out is Php 450.00 naman daw.
Pero these are prices for trucks and SUV's. Mahal ang sa kotse.
February 15th, 2004 01:40 PM #10
teka tuwing kelan ba dapat ginagawa ang wheel camber and alignment? Kasama ba sa periodic maintenance ito? Ako kasi I just do this kung may papalitang parts sa suspension ko.
Yung steering ko kasi ngayon parang maluwag na..may play na kung baga. Will this be corrected kung magpa-align ako? Considering that my suspension parts are all A-ok of course..
