Page 1 of 2 12 LastLast
Results 1 to 20 of 68
    Hi guys! Can you recommend a shop/s which could repair power steering problems. Me humming sound kasi ung 96 Sentra ko pag tinuturn ko especially pag malapit na sa sagad, at saka pag nag mamaneobra ako. Kung minsan meron ding sound na "tok" pag nasagad na sa turn. I tried ipaayos to pero di naman narepair ng mekaniko dito sa min. Preferrably shops in the areas of Marikina or Commonwealth. Pero kung sa ibang locations, cge pakirecommend na rin. Tnx!!
    try to contact ferdie, 02-3603268 or 09109209881. Nasa Obrero near the R. Papa LRT station. He works on all of my power steering problems. But before that see if nasa level yun fluid mo. Baka kulang lang.
    Mar 2003
    A bit OT...does a humming sound really indicate that there's something wrong? I've been hearing it on mine, although barely noticeable specially when radio is on. Other than that, ok naman sha.
    Thanks and pasensha na po.
    Yap, i know there's something wrong. Kasi medyo mabigat manibela compared to other 2 nissan sentras my brother-in-law have which i get to drive once in a while.
    Pinaayos ko PS ko sa may anonas yun tapat ng Zafra Motors. Binaklas ng ibang mekaniko tas nang binalik ndi na nagana yung PS. Sila nagayos. malapit yun sa kamias.
    Oliver, anu previous sira ng PS m? Anu pinalitan nila? Nakamagkano k?
    Feb 2007
    Hi Lanss, if oil seal ang problem ng PS mo pa manufacture ka na lang sa COSCO (Caloocan Oil Seal Corp.). Mas matibay manifactured oils seal kaysa sa oil seal na kasama sa repair kit ng PS.
    May 2011
    guys recommended shops sa banawe na magaling sa Power steering? CRV first gen pala yung car, naubos power steering fluid ko kagabi sa 5 hours traffic dahil sa INC na yan... may leak lang naman hindi pa naman sira motor
    Quote Originally Posted by 3GEMS View Post
    Hose related leak or from the PS rack? Last time i had our PS rack on the Galant overhauled, it was done by Cruven. Not the cheapest but they got the job done. After that my only PS related problem on that car was getting the system properly bled.
    Try going to a shop convenient to you. For what car is this and what area are you located at?
    May 2011
    CRV first genenration... we don't know yet kung san ba source ng leak.. how much damage sa cruven? banawe sana, dito lang kami around samplaoc
    Kung hose, sa ABC Hydraulic ko lang pinapagawa. La pa Php1000.00 yung sa Civic. Expect a CR-V hose to cost the same. Pero pa-diagnose mo muna.
    May mga honest shops naman sa Banawe like Wheelers or kung Sampaloc ka, Selecta Drive along A.Bonifacio is not that far. You can visit Dr. G's car clinic (yes Dr. G is a real medical doctor in case anyone is wondering). They are fair and honest and will not overcharge or shortchange you. Don't be intimidated if all you see on the lot are Benzes and Land Cruisers. It just so happens that's their favorite brand and model. But they will work on almost anything. Look for GP sa Dr. G's (anak siya ni Dr. G.)
    Si vinj ang kilala no wheelers eh. They dont know me pero never ko pa naman na feel na dinaya nila ko. Yun lang they are not the cheapest but honest naman. Walang extra work na dinadagdag. Try mo pa tawaran. Baka good mood sila. Hehe
    Sino nagkabit ng surplus? So sa ibang area po siya nag leak? Bukod pa sa nirepair?
    May 2011
    si Toto likod ng multimotors malapit na sa e.rod.. kilala mo?power steering specialist orig. din pinalit pareho (part number ata un).. mukhang marunong naman sila kasi alam nila yung agagawin sa airbag.. and wala pang 2 hours ginawa hehe.. sana wag na bumalik leak sakit sa ulo and malapit na change oil sabay sabay gastos
    sa ibang part naman nagkaleak sa may shaft daw ang leak, before buksan sa wheelers wala namang leak dun... pansin ko after pagawa sa wheelers may tok na sound pag kabig ko sa kanan...
    nung napalitan ngaun ng surplus nawala nanaman yung tok..
    Feb 2012
    3GEMS anong update sa power steering mo? i'm planning to buy surplus din. I have mine repaired 2x last year. balik pa din yung leak. How much un labor ng kabit? can you post saan binili yung surplus PS? kasama mo ba bumili yung mekaniko or hindi? TIA!
    May 2011
    Quote Originally Posted by V!S View Post
    update on my steering...
    since nung pinalitan ng surplus hindi pa ako nagdagdag ps fluid, wala ng leak and mas gumaan pa ... hindi na namin kasama yung gumawa... maya hanapin ko calling card nila post ko address and no. para matawagan mo muna...
    sa kanila din galing yung surplus na pinalit... makita mo store nila walang ibang laman kundi PSteering..
    si Toto kausapin para maayos kausap dami kasi boy nun... naka discount kami kasi visaya si Toto hehe nagbisayaan lang discount na... 6k lahat iwan mo na ung papalitan nila psteering mo...sila na kakabit mga 1 and half hour lang ginawa.. 3 months waranty..
    mas madugo ang PSteering kapag repairkit.. pag surplus palit buo may waranty kapa ..
    May 2011
    Power Steering Specialist
    103 BMA Avenue, Tatalon, Quezon City
    Tel. no.: 412-0431
    Renato "Toto" Dalomino
    pag galing ka sa Q. Ave North bound right ka sa Banawe then bago ka aabot ng E. Rodrigez last na kanto kaliwa sa Kitanlad Street then right ka BMA Ave malapit na malapit na... or google mo nalang
    Feb 2012
    tnx. check ko to. my konting budget na ko.
    Jun 2012
    If you overhauled your power steering/rack and pinion and the leak came back, it is probably the rack and pinion itself. Your repair man should clean the rack and pinion rod itself to see if there are scratches on it. If the scratches are there, the leak will come back. You need to replace scratched rack and pinion rod. Surplus is OK as long as it shows no scratches when it is clean.
    Also check your bushing and axle boots because leaks from the rack and pinion assembly can damage them.
    Jul 2015
    Magkano po kaya estimate sir pag pina overhaul ko ung powersteering.
Pls recommend Power Steering repair shop
