Results 1 to 10 of 10
    Dec 2010
    Guys help lang, nagpalit kasi ako ng brandnew na mags 18" with 235/40 tires, nun tnest drive ko na nagwiwigle on *100kph+ and kumakabig ang manibela pagnalulubak? Ano kyang fix ang gagawin ko? Isosoli ko sa shop para macheck. Yung old tires ko is 205/55 16"
    Baka hindi balanced or hindi naka align ng mabuti.
    Dec 2010
    sir mda, may alam ka ba magaling mag align sa bandang south NCR?
    May 2009
    that problem most of the time is due to dynamic imbalance....take note that you put more resisting force in the steering system in the form of bigger tires.
    Quote Originally Posted by Topdrive21 View Post
    boss sa Bridgestone Tire Center in Alabang sa may Madrigal Business Park near Army Navy at Total Gas Station if you are from the very South of NCR talaga if here ka sa Makati area may Bridgestone na din sa Pasong Tamo, they are one of the best in aligning. hth.
    Dec 2010
    guys wala daw sa system nila ang car ko, tumawag ako sa casa and nirefer ako sa wings west. inalign nila yun wheels sa front kasi naka -30deg sa right at +30deg sa left. ang limit is 15deg lang +/-. But then sabi ng technician its due to my tires daw, lalo na ang brand westlake. madaling sumunod sa shape ng road eh kya kumakabig ang manibela. hindi naman brake yun kasi di bnaman kumakabig pagbinabrake. try ko daw i-rotate yung rear left to front left. kaso di ko muna tnry pina-balance ko muna, nirefer ako sa minerva sa westgate. Hi-speed balancing daw ang service nila. then pinacorrect ko and overall check ng condition ng tires and wheels. good naman daw. then test drive nun pauwi ako. *120kph nagbavibrate yung steering wheel pero napakahina na. before sa 100kph+ vibrate na siya parang cellphone. pero after nun alignment may slightly pull pa din sa left side. at pansin ko bumigat ang steering wheel ko, mabigat as in pihitin. help naman ano pa marerecommend niyo.
    salamat
    Jul 2003
    can you post the model of your car?
    Jun 2010
    salamat
    Argh, I'm also 18s on low profile Westlakes! And my steering wheel also vibrates at high speeds. If the wheel balancing didn't work, how about changing your tires to a better brand? And then tell me if the wiggle disappeared so I can change mine as well hehe.
    Good luck dude and give us feedback if you were able to solve the problem so I'll know what to do with mine...
Please help! Steering wheel vibration and bump steer after changing wheels
