Ano ba mas maganda sa dalawa? Im having "2 lift suspension and im confused between the 2 brand. Please help me decide guys and thank you
ako nagamit ko na both ironman/procomp/ rancho....
i would recommend kung hindi ka naman mag offroad at heavy ang dinadala mo lagi, ironman... either nitrogas or foam cell pro.
kung madalas meh karga ka at gsto mo ng adjustment rancho.
pinaka soft ang procomp na shocks. mas malambot pa sa OEM. boaty yung ride.
right now im using rancho na RS9000xl adjustable... napaka ganda ng ride at shock dynamics. plus adjustable pa.
OEM??? Sorry parang stock shocks ata yan sir or you mean old man emu. Malambot ba yung ironman nitro gas? San mo nakuha procomp mo? Thanks
Both suspension systems are Australian made and among the best. It all boils down to how you're going to use your rig daily. Both systems offer springs accdg to use: light duty, medium duty and heavy duty. These set are all tuned for such ex: "medium duty" set comes with coil/leafspring, shock absorbers, poly bushings, U-bolts, etc. They come as a "tuned" set. 2" lift is actually OEM height, but at least you don't have to modify brakelines, steering shafts, propeller lengths, etc. As long as you keep your lift within the 2-3" height, steering geometry won't stray from OEM specs...
im on iron man... medyo matigas ... sabi nung mga ka tropa ko mas maganda daw lumaro ang dobinsons...
madami talaga nagsasabi matigas ang iron man...
up on this,
guys anong suspension ba ang 3" lift tapos ang priority mo is comfort? wala naman laging dalang mabigat minsan lang kapag nag grocery or out of town.
daily use yun sasakyan sa work.. so need ko sana yun comfort with 3" lift... planning to upgrade my tires din kasi after the 3" lift
TIA
up on this,
TIA
kung gusto mo malambot use PROCOMP, most aftermarket off-road are designed for added load capacity kaya medyo matigas, pero if you have the budget get the adjustable ranchos para you always have the best ranges of settings
Buhay pa pala thread ko... anyway i already purchased ironman nitro gas for my vigo. Nawala talaga yung tagtag ng oto ko. I used lift blocks para sa likod and ironman coil sa harap. Question lang mga masters mas maganda ba kung lift block or yung tinatawag nilang lifting comfort shackles?? Ano ba pagkakaiba nila?
pag comfort shackles, it will provide more leaf spring travel, mas maganda compared sa lift block.. sa lift block, you just moved the whole leaf spring away from the body but did not alter the suspension.
alin ba mas maganda gamitin pag heavy load for Hilux yung Dobinsons or Tough Dog? we're currently using comfort shackles with stock suspension kaso pag may load na feeds yung Hilux parang nag bobottom yung shocks.
Mga boss, sino na dito nakagamit ng Fox Shocks and Old Man Emu BP-51? Alin ba sa dalawa yung mas maganda mga boss? For Hilux Vigo sana. Balance sana ang habol ko, comfortable ride at minsan nagkakarga din ako sa likod usually mga 700 kgs. mga 1x a week. Salamat in advance mga boss! No steel bumpers (front and back).
Tough dog is adjustable... Hard to soft...
Dobinsons- they have comfort coils.. And load carrying coils...
Kung sumasagad Ang stock shocks mo... Sasagad din ang after market shocks and coils...
Baka naman your shocks needs replacement Na?
gumamit ka sir ng ironman load plus.... after installing it sa leaf springs ng hilux mo, buy a rancho, then put it at setting 9. impossible pang mag bottom out yan.
sa eve at stock spring pero at rancho setting 9, i can put almost 600kgs of load and hindi man lang umaabot midway sa stock na bump stops..
Fox nasa 80-90k na ata Yan.. Blistein 60-70k..
Dobinsons - dalawang klase Kasi yan, meron comfort.. Meron din Pag naka steel bumper ka.. Pag comfort hindi naman matagtag..
Ang matigas Yung iron man...
