Results 1 to 10 of 35
November 9th, 2014 07:24 PM #1
Ano ba mas maganda sa dalawa? Im having "2 lift suspension and im confused between the 2 brand. Please help me decide guys and thank you
November 10th, 2014 01:34 PM #2
ako nagamit ko na both ironman/procomp/ rancho....
i would recommend kung hindi ka naman mag offroad at heavy ang dinadala mo lagi, ironman... either nitrogas or foam cell pro.
kung madalas meh karga ka at gsto mo ng adjustment rancho.
pinaka soft ang procomp na shocks. mas malambot pa sa OEM. boaty yung ride.
right now im using rancho na RS9000xl adjustable... napaka ganda ng ride at shock dynamics. plus adjustable pa.
November 10th, 2014 04:29 PM #3
OEM??? Sorry parang stock shocks ata yan sir or you mean old man emu. Malambot ba yung ironman nitro gas? San mo nakuha procomp mo? Thanks
- Apr 2009
- 429
November 16th, 2014 06:09 PM #4Both suspension systems are Australian made and among the best. It all boils down to how you're going to use your rig daily. Both systems offer springs accdg to use: light duty, medium duty and heavy duty. These set are all tuned for such ex: "medium duty" set comes with coil/leafspring, shock absorbers, poly bushings, U-bolts, etc. They come as a "tuned" set. 2" lift is actually OEM height, but at least you don't have to modify brakelines, steering shafts, propeller lengths, etc. As long as you keep your lift within the 2-3" height, steering geometry won't stray from OEM specs...
November 20th, 2014 06:34 AM #5
im on iron man... medyo matigas ... sabi nung mga ka tropa ko mas maganda daw lumaro ang dobinsons...
madami talaga nagsasabi matigas ang iron man...
June 15th, 2015 11:25 AM #6
up on this,
guys anong suspension ba ang 3" lift tapos ang priority mo is comfort? wala naman laging dalang mabigat minsan lang kapag nag grocery or out of town.
daily use yun sasakyan sa work.. so need ko sana yun comfort with 3" lift... planning to upgrade my tires din kasi after the 3" lift
TIA
up on this,
TIA
June 16th, 2015 10:21 AM #7
kung gusto mo malambot use PROCOMP, most aftermarket off-road are designed for added load capacity kaya medyo matigas, pero if you have the budget get the adjustable ranchos para you always have the best ranges of settings
June 16th, 2015 01:16 PM #9
sir miko, sorry noob question pero you mean po ba sa adjustable eh pwedeng soft pwedeng hard? or adjustable yun height?
nasa magkano po price range ng PROCOMP at ng RANCHOS sir? para may idea lang po...
thanks po :D
thanks po :D
June 16th, 2015 10:27 PM #10
mag two years na ako naka rancho. once a week nagkakarga ako nang 400 kilos. napaka ganda gamitin nang rancho.
yung number 1 setting ay talagang malambot, at yung 9 naman talagang walang galawan shocks mo.
considering na torsion bar ako sa harap at leaf springs and likod ko, ramdam mo ang effect pag nasa 1 lang setting.
i have already tried the ironman and procomp, pag ginamit mo sila off-road o kapag meh cargo ka mabigat they won't last long, masisira agad. usually at 3 years lang, sa rancho i think it will serve the life of the vehicle bago masira.Last edited by miko101130; June 16th, 2015 at 10:34 PM.
