Results 1 to 6 of 6
May 3rd, 2008 07:27 PM #1
Hello mga suspension guru's
pa share nalang po ng mga experience niyo, by answering the following problem:
Ano mga symptoms pag may sira mga bagay na to:
1.) Shocks
2.) Spring
3.) Stabilizer link
4.) Ball joints
5.) Tierod
6.) Rack end
7.) Rack and pinion
8.) CV Joints
Pasagot nalang po, hinde lang po sa akin to, para nadin sa lahat...
Thanks in advance sa mga sasagot..
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 4th, 2008 05:25 PM #2lahat yan iingay. now you have to be able to pinpoint which one is causing the noise by either checking freeplay yourself or showing it to a mechanic to see which parts are worn out na.
May 4th, 2008 10:12 PM #3
SHOCKS- uneven wear ng tire(feather wheel), matalbog ang kotse (konting pot hole...boooooog) and possible lost control on a high speed.
SPRING- Matalbog ang kotse, tabingi ang itsura ng sasakyan.
STABILIZER LINK- Help's reduce body roll ng kotse at iingay din ito kapag sira, it's very easy to fix.
CV joints- kapag sira ito parang machine gun ang tunog(well not exactly in my mind) Check CV boots pag may cracked at labasan na ang mga grease palitan na agad.
May 5th, 2008 09:28 AM #4
Shocks:
a) Maalon ang ride
b) May tunog
Springs:
a) Normally, ride quality is affected. Matagtag.
b) Physically, hindi pantay ang tayo ng oto.
Ball Joints:
a) May kabig o wiggle
b) May tunog
Rack End
a) May kabig o wiggle din.
b) May tunog din.
c) Unstable on high speeds
CV Joints
a) May kumakatok during turning
- Jul 2008
- 10
November 9th, 2008 07:09 PM #5
- Nov 2003
- 3,849
