Results 1 to 10 of 17
February 3rd, 2015 10:47 AM #1
Newbie question mga sir:
May nabasa kasi ako na di recommended ang paggamit ng parking brake after a long drive? How true is this? and why?
February 3rd, 2015 10:52 AM #2
February 3rd, 2015 10:55 AM #3
+1 bakit daw?
Parking brake is handbrake? Tama ba?
February 3rd, 2015 10:57 AM #4
Hot pads stuck against hot discs (or hot shoes against hot drums) could cause material transfer between the two and cause rough braking until the material is worn away. It could also cause warpage because of uneven cooling.
It's not an issue with normal driving unless you live at the bottom of a 1 km downhill driveway braking all the way. Our brakes don't get red hot under normal usage. By the time the car settles into its final parking spot its brakes should have cooled enough to not worry about any parking brake issues. Besides it's more expensive to repair damage from a runaway car than to replace brakes ;)
February 3rd, 2015 11:13 AM #5
It's not an article, it's a discussion in a facebook page.
I didn't know the person who said that or I'm not sure how knowledgeable he is when it comes to cars.
That's why I'm confirming it here. Masama bang mag confirm ng question?
Let's just close this forum instead then and mag rely na lang tayo sa mga articles.
Masyado kang seryoso sir.
February 3rd, 2015 11:18 AM #6
- Jul 2012
- 233
February 3rd, 2015 11:22 AM #7i don't engage parking brake after doing a 5 hot laps on race track (because hot). also after a long drive on heavy rains only (because wet). on normal long drives, i park the car normally with parking brakes engaged.
February 3rd, 2015 11:32 AM #8
even if your rear brakes are drum or disc, the rear brakes only get about 30-40% percent of the braking power.
most of the heat is generated at the front wheels so no issue ang pad glazing or warping ng rotors. this applies to regular street driven vehicles..
you cannot make your rotors or drum glow by regular driving even spirited driving.
tsaka TS, when you say long drive that means freeway/expressway driving, its rare that you will frequently slam your brakes while in the freeway just to generate heat sa brakes.
baka yung article na nabasa mo is geared towards track/racing... doon pwede mo ma glaze yung pad mo at magkaroon ng material transfer.
anyways you do not have to worry about engaging your parking brake, mas nakakatakot kung ayaw mag engage parking brake mo. haha.
February 3rd, 2015 12:06 PM #9
February 3rd, 2015 05:56 PM #10
tama! sa racetrack when you enter the pitstop you shouldn't use your handbrake pero on regular driving no need to worry since di naman ganon ka heavy gamit natin sa brakes natin pag daily driving lang. kahit itakbo mo pa ng baguio yan pwede mo i hand brake agad yan.
