Results 1 to 9 of 9
    May 2004
    sirs,
    would you know what's the use of that white ceramic thing, about 40x20 cm, inside the brake fuid reservoir?
    i saw it floating in the reservoir of my 7G galant... di ba delikado 'to? i think i saw a screw hole, pero broken...
    thanks in advance!
    silhouette
    My doubtful guess, ceramic floater attracts water? -- So that the brake fluid that runs along the line is almost waterless.
  3. #3
    i think its for the brake fluid sensor warning..ung nailaw kapag low brake fluid level..
    kung sensor bakit ceramic??? uso na ba ngayon ang ceramic floater kesa rubber floater ???
    :confused:
    ang rubber nagdedeteriorate in time? while ceramic will stay the same? ganun kaya?
    Signature
    May 2004
    can i replace it without replacing or removing the reservoir? just drain the fluid... where can i buy one?
    gracias!
  7. #7
    gracias!
    sir,dont know kung naalis yan ng dudukutin lang sa baso/reservoir.havent tried it yet,e..
    try mo sa surplus shops...(ex. sa banawe)-->masmaganda kung dala mo ung part as sample.
    pero i doubt kung un lang bebenta nila...baka ung buong master brake..pero malay mo,mayroong ganun lang binebenta...
    i think di nagbebenta ng ganyan lang ang brandnew..kung meron man,baka mahal..
    hope i helped..
    May 2004
    thanks AY!
    tingin ko nga hindi nakakabili nun. malamang buong reservoir.
    i'll just drain the fluid ang check what else can i do.
    gracias senyor!
  9. #9
    you're welcome!
ceramic in brake fluid reservoir?
