Results 1 to 9 of 9
December 13th, 2004 03:34 PM #1
sirs,
would you know what's the use of that white ceramic thing, about 40x20 cm, inside the brake fuid reservoir?
i saw it floating in the reservoir of my 7G galant... di ba delikado 'to? i think i saw a screw hole, pero broken...
thanks in advance!
silhouette
December 13th, 2004 04:34 PM #2
My doubtful guess, ceramic floater attracts water? -- So that the brake fluid that runs along the line is almost waterless.
December 14th, 2004 06:34 PM #3
i think its for the brake fluid sensor warning..ung nailaw kapag low brake fluid level..
December 14th, 2004 06:39 PM #4
kung sensor bakit ceramic??? uso na ba ngayon ang ceramic floater kesa rubber floater ???
:confused:
December 14th, 2004 07:43 PM #5
ang rubber nagdedeteriorate in time? while ceramic will stay the same? ganun kaya?
Signature
December 14th, 2004 07:47 PM #6
can i replace it without replacing or removing the reservoir? just drain the fluid... where can i buy one?
gracias!
December 14th, 2004 08:08 PM #7Originally posted by silhouette
gracias!
try mo sa surplus shops...(ex. sa banawe)-->masmaganda kung dala mo ung part as sample.
pero i doubt kung un lang bebenta nila...baka ung buong master brake..pero malay mo,mayroong ganun lang binebenta...
i think di nagbebenta ng ganyan lang ang brandnew..kung meron man,baka mahal..
hope i helped..
December 15th, 2004 11:29 AM #8
thanks AY!
tingin ko nga hindi nakakabili nun. malamang buong reservoir.
i'll just drain the fluid ang check what else can i do.
gracias senyor!
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
