Results 1 to 10 of 20
June 2nd, 2003 10:33 PM #1
Take my case as an example:
OEM tire dimensions for the Suzuki Vitara is 205/70R15. The recommended tire pressure as stated in the door sticker is 23 psi front and 23 psi rear.
I changed my tires 2 years ago to BF Goodrich T/A All terrain 235/75R15. Are the OEM tire pressures still applicable to my current tires? Currently, they are at 28psi cold for both front and rear.
June 2nd, 2003 11:10 PM #2
AFAIK, same lang ang tire pressure even if you changed to a wider and taller tire. Maybe Suzuki wanted to maintain the soft plush ride kaya nila pinalalagay sa low pressure ang hangin. Believe it, even if I have 33 inch tires on my ride, we have the same tire pressure.
June 3rd, 2003 08:28 PM #6
I'm running now at 25psi. Adjusted it early this am before leaving for PGH. Syet! Grabe ang improvement ng ride. Di na matagtag and "damp" na ang feeling. Tried doing hard braking and cornering. Same pa din ang performance. I think I'm sticking to 25psi for the meantime.
June 3rd, 2003 09:07 PM #7
marwen::: Here is a link for easier conversion. :D Convert metric to inch tire sizes click here!
June 4th, 2003 08:17 AM #10Originally Posted by kiperSignature
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
