Results 1 to 6 of 6
    Nov 2004
    Fellow forumers
    My friend noticed that malakas na ugong > 80 kph pag nasa slex ako. and upon shifting to neutral no gas may ugong pa rin. He concluded na wheel bearing ito.
    Magkano ba uma abot ng pagawa nito at gaano katagal?
    Any parts should i check also aside from the bearing ?
    Other parts that should be replaced same time:?
    Thanks
    Feb 2005
    Yeah the wheel bearing could be the likely culprit. Mura lang pagawa niyan (Depending on the bearing you get, mahal na siguro ung 2k including labor), siguro kaya in 1 hour or less. Check mo lang maigi san nanggaling yung ugong, kung sa rear left or rear right, or baka pareho.
    Pwede rin sa brand of tires na gamit mo galing ang ugong. Better listen first before spending
    Jul 2010
    Check the tires first. The wheel bearings if busted will make noise regardless of speed.
    Sep 2005
    maraming pwedeng panggalingan yang ugong.. ano ba sasakyan? pwede din sa roof rail.. pwede din kung may door visor..
    Nov 2004
    The tires are bridgestone about less than a year old. both front wheels
    May ugong din at low speeds pero di ganun kalakas.
    Ride is Altis 1.6 matic
    Thanks
Ugong on high speeds in SLEX
