Results 1 to 6 of 6
- Nov 2004
- 45
March 10th, 2011 12:04 PM #1Fellow forumers
My friend noticed that malakas na ugong > 80 kph pag nasa slex ako. and upon shifting to neutral no gas may ugong pa rin. He concluded na wheel bearing ito.
Magkano ba uma abot ng pagawa nito at gaano katagal?
Any parts should i check also aside from the bearing ?
Other parts that should be replaced same time:?
Thanks
March 10th, 2011 01:25 PM #2
Yeah the wheel bearing could be the likely culprit. Mura lang pagawa niyan (Depending on the bearing you get, mahal na siguro ung 2k including labor), siguro kaya in 1 hour or less. Check mo lang maigi san nanggaling yung ugong, kung sa rear left or rear right, or baka pareho.
March 10th, 2011 01:31 PM #3
Pwede rin sa brand of tires na gamit mo galing ang ugong. Better listen first before spending
- Jul 2010
- 165
March 10th, 2011 02:00 PM #4Check the tires first. The wheel bearings if busted will make noise regardless of speed.
March 10th, 2011 02:55 PM #5
maraming pwedeng panggalingan yang ugong.. ano ba sasakyan? pwede din sa roof rail.. pwede din kung may door visor..
- Nov 2004
- 45
March 10th, 2011 05:02 PM #6The tires are bridgestone about less than a year old. both front wheels
May ugong din at low speeds pero di ganun kalakas.
Ride is Altis 1.6 matic
Thanks
Thank you!
