Page 4 of 12 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 420
    Jun 2006
    OT
    Pano ba malalaman ang tire size? hiram ko kasi 94 corolla ng pinsan ko and hindi ko alam size and ilan dapat PSI lagay ko?
    Quote Originally Posted by jonski View Post
    OT
    naka sulat sa sidewall ng tire.
    assuming yung corolla nung pinsan mo eh naka stock, its 185/65/14.
  3. #3
    maverick: Baka may tagas tires mo pa check mo na rin.
    just wanted to share...
    just had my 18inchers filled with it and so far the ride became softer...
    Sep 2004
    same psi din ung gagamitin di ba?
    Aug 2003
    you can use a higher psi if you wish. you can dial in a higher psi and not risk the danger of blowing up your tires when they heat up in the course of travelling -- unlike tires inflated with plain air. that why it's being touted as a fuel saver, less rolling resistance for higher inflation rates.
    Sep 2005
    Hmm.. Pede kaya magparefill ng CO2 tank, ung pang airgun ng N2 sa mga shops? para kapag lumambot ung gulong mo e matagal mo na kailangan pumunta sa kanila for refill?
    May 2004
    ano na update sa nitro filled tyres?
    an update... last weekend when i had my timing belt and other parts (tensioner bearing, waterpump, alternator and aircon belts and engine support) changed sa Minerva, had also inflated my tires to nitrogen (costs 50 pesos/tire). medyo gumaang and masarap patakbuhin ngayon yung oto dahil parang magaang yung goma mo.
    had talked too with other nitro users. they attest that sometimes, they go on using their tires without their tires falling under pressure for at most 6 months. kaya daw minsan talaga ok lang daw sa kanila magbayad ng 200 pesos kasi walang abala.
    Jul 2005
    Quote Originally Posted by happy_gilmore
    sir... san kayo nag pa-inflate??(minerva) mura yang 50 per tire ah...
    TIA
    Dec 2003
    6 months... wow... hope i could dropby minerva sometime after the holy week to try this one.. if this will last for 6 months, sobrang sulit na.....
    Quote Originally Posted by mugen
    i hope ganun nga.... pero i think syempre. you have to check your tire pressures every now and then.
  15. #15
    happy_gilmore: saan ba yung minerva
    Quote Originally Posted by ILuvDetailing
    filinvest alabang pre.
    Aug 2007
    Quote Originally Posted by ILuvDetailing View Post
    meron din minerva tire gallery along macapagal avenue; adjacent to petron gas station (coming from cavite, on one's right). . .
    Jul 2005
    ngek sori... naunahan ako... hehehe
    Dec 2003
    yup... while reading on this thread.. it makes me curious to try and check it out myself... sulit naman eh... 200petot.. sa panahon ngayon kelangan na maging wais..
  20. #20
    susubukan ko din. now to find time and visit minerva.
Nitrogen for Tires [Merged]
