minerva is located at alabang ata. there's a whole thread at hcp dedicated for nitrogen-filled tires![]()
westgate, alabang. at the back of Total gas station, right after Alabang town center.
hindi po ba samasabog ang nitrogen?
parang NOS hehe :D
pag lumambot po ang gulong nasa province ka pwede po bang haluhaan ng ordinary air?
tnx
FYI... ordinary air is already 79% nitrogen.
IMO... it is only beneficial when you do a lot of high-speed & long driving... or you do some track time.
hmm may contact po kayo ng minerva.. thinking of getting mine nitrogenized.. hehe
gaano katagal ang nitrogen compared sa normal lang?
minerva is at westgate alabang, yup they charge 50 pesos per tire but unlimited refills. i've refilled 3 times na to get the psi na gusto ko talaga which is 34psi for my 195/55R15 tires. ok service nila
as for nitrogen itself one of the biggest advange over oxygen is that it maintains the tire pressure. as you all know, ordinary air expands an additional 4-5 psi when your tires have warmed up. you'll feel na mas matigas yung tires mo compared to when you just started the engine and drove. with nitrogen the pressure remains the same.
nitrogen is an inert gas and does not explode, maybe you got it confused with hydrogen?
sabi ng mekaniko dun 100 per tire daw... i just got a set of 4 tires from minerva last week. nga pala, may free yokohama umbrella for every two tires of yokos purchased hehehe
mazda... hehehe onga, the air we breathe is already 80% nitrogen hehehe
SUV ba sir? yung 50 pesos nga pala for cars lang, 100 nga yata for AUV/SUVsOriginally Posted by cardo
Make sure that the shops are using food grade nitrogen gases. Ordinary nitrogen gases are only compressed air with higher nitrogen content.
pano mo machechek ung shop kung FOOD GRADE NITROGEN nga ung kinakargaOriginally Posted by zeagle
That's the problem you can't. You just have to go to a reliable shop. Teka check ko yung coding ng tank namin.Originally Posted by gaby_bear03
mga sirs, ang alam ko gumagamit sila ng nitrogen generator to pump nitro sa tires. mukhang malabo na food grade ang gamit nila.
so ok lang ba to mix ordinary air n nitrogen?
pano kung naka nitrogen ka and then lumambot at walang malapit na nitrogen station?
Originally Posted by buknoy2002
ok lang i-mix. problem ngayon ng linagyan ng ordinary air na tire, hindi na siya accurate ulit..have to shell out another refill for a tire..ako ni-tiyatiyaga ko pumunta sa tireboy pag nakikita kong malambot mga gulong ko..sayang yung 300 petot na binayad ko e![]()
sa mga gumagamit ng nitro ano po talaga advantage and disadvantage ? :-)
