Newbie question mga sir:
May nabasa kasi ako na di recommended ang paggamit ng parking brake after a long drive? How true is this? and why?
It's not an article, it's a discussion in a facebook page.
I didn't know the person who said that or I'm not sure how knowledgeable he is when it comes to cars.
That's why I'm confirming it here. Masama bang mag confirm ng question?
Let's just close this forum instead then and mag rely na lang tayo sa mga articles.
Masyado kang seryoso sir.
i don't engage parking brake after doing a 5 hot laps on race track (because hot). also after a long drive on heavy rains only (because wet). on normal long drives, i park the car normally with parking brakes engaged.
even if your rear brakes are drum or disc, the rear brakes only get about 30-40% percent of the braking power.
most of the heat is generated at the front wheels so no issue ang pad glazing or warping ng rotors. this applies to regular street driven vehicles..
you cannot make your rotors or drum glow by regular driving even spirited driving.
tsaka TS, when you say long drive that means freeway/expressway driving, its rare that you will frequently slam your brakes while in the freeway just to generate heat sa brakes.
baka yung article na nabasa mo is geared towards track/racing... doon pwede mo ma glaze yung pad mo at magkaroon ng material transfer.
anyways you do not have to worry about engaging your parking brake, mas nakakatakot kung ayaw mag engage parking brake mo. haha.
+1 bakit daw?
Parking brake is handbrake? Tama ba?
Hot pads stuck against hot discs (or hot shoes against hot drums) could cause material transfer between the two and cause rough braking until the material is worn away. It could also cause warpage because of uneven cooling.
It's not an issue with normal driving unless you live at the bottom of a 1 km downhill driveway braking all the way. Our brakes don't get red hot under normal usage. By the time the car settles into its final parking spot its brakes should have cooled enough to not worry about any parking brake issues. Besides it's more expensive to repair damage from a runaway car than to replace brakes ;)
tama! sa racetrack when you enter the pitstop you shouldn't use your handbrake pero on regular driving no need to worry since di naman ganon ka heavy gamit natin sa brakes natin pag daily driving lang. kahit itakbo mo pa ng baguio yan pwede mo i hand brake agad yan.
Wala pa naman ako manual na nababasa na nagsasabi na you cannot use handbrake/parkig brake after a long drive.![]()
OK le's assume that the argument is true, what if after driving a "long drive" kailangan mo na talagang mag CR sa gasoline station, as in kailangan mo na talaga at ikaw lang mag-isa sa sasakyan. Tapos ang available lang na parking slot ay elevated pa by 20 degrees, does it mean na hindi mo eengage yung parking brakes at all? Tapos hanap na lang ng bata pang kalso.
Tama si Ry_Tower, I don't remember reading anything from the user's manual na bawal gamitin yung parking brakes after normal use.
Pero what if severe driving style ang nangyari, tipong galing sa taas ng Baguio at pababa, tipong racing mode pababa kung baga, ok lang kaya na gamitin yung parking brakes sa baba kung sakaling naisipan nating mag picture-picture ng biglaan?
OK le's assume that the argument is true, what if after driving a "long drive" kailangan mo na talagang mag CR sa gasoline station, as in kailangan mo na talaga at ikaw lang mag-isa sa sasakyan. Tapos ang available lang na parking slot ay elevated pa by 20 degrees, does it mean na hindi mo eengage yung parking brakes at all? Tapos hanap na lang ng bato pang kalso.
I've experienced going up and down a mountain with heavy braking (engine and the brakes-kasama pa hand brake at footbrake niya ha to make sure na hindi mag-fade ang normal brakes ko). And upon reaching the foot of the mountain eh nakapag-handbrake na din ako kasi napapa-jingle. Hindi din nag-stuck handbrake.
Again nagagamit ko pa handbrake niya pang-alalay sa footbrakes ha.
I drove 300km today...and i used my parking brake. Ano masisira.....wala lol.
