Results 1 to 20 of 27
    Hi Guys,
    Need help. Meron kasing tumutunog kapag nagbebrakes ako. Parang "tukutok-tukutok" na sound - isipin nyo ung parang tunog sa roleta. Parang may tumatama, nawawala siya kapag bibitawan ko na ung brakes pero kung tumutunog na habang nakadiin ung brakes tapos kung lalong didiinan ung brakes, mas lalakas ung tunog nya. Ano po kaya ito?
    nangyayari siya kung bebreak ka minsan habang pababa ka or may lubak. Hindi regular ung occurence nya, minsan naeexperience minsan naman hindi. Help pls. TIA
    Harap o likod?
    All disk o hindi?
    Nov 2007
    As Gtootsie said, pls indicate where, front rear brakes? all disk or combination of disk and drum. This info will help us to figure it out the problem.
    Jun 2005
    sir, the problem there, i think, are the brake pads. they are already worn out or worn uneven that when you engage them and it locks on to the disk brakes, the caliper rattles again its brace causing the "tokotok" sound. had that same problem with my honda civic lxi front brakes.
    you can replace the brake pads to correct it or if the pads are still thick, you can have the discs re-faced. but if the sound is coming from the rear, which is drum brakes, again, replacement of the pads would be the solution.
    but better yet, have a mechanic from a good shop check it out to find out the exact solution.
    hope this helps..
    Kung galing sa front yung ingay, possible ngang brake pad or brake caliper. Pwede ding ball joint, nangyari na din ganito sa auto ko.
    Oct 2007
    Pasabay na rin po sa thread na ito.
    My civic front discs is making this whislting sound. Nakapagtataka kasi minsan-minsanlang sya mangyari. Also, if I suddenly push the brakes, walang tunog. pero pagdahandahan nandun nanaman sya. Tumutunog din sya pag galing ako sa full stop and dahan dahan akong nag aacelerate.
    What do you guys think? San ba pwedend ipadiagnose ito?
    Dec 2007
    Quote Originally Posted by stolen*soul View Post
    Hi Guys,
    tol
    check mo if step on mo ang brake pedal eh parang bumabalik ba?
    if bumabalik parehas tayo ng sira, pinalitan yung rotor assembly kasama na yung bearing at yung 4 stud P850 lang yun sa satoshi at labor P500 ata mahirap kasi magbaklas nun eh
    much better pa lifter mo ang kotse at patakbuhin pra umiikot ang tires dun nila makikita yun
    Apr 2008
    Pls help me also. I have a 97 VTI and everytime I brake may noise din. I brought it to several repair shops na din like servitek, rapide, etc but hindi nila maalis yung noise. They checked the caliper pins, brake pads, disc, etc ok naman daw lahat. Yung noise is parang may loose na screw everytime I brake. Is there a shop in alabang or paranaque area na brakes specialist that you can recommend?
    Nov 2003
    it may be the pads themselves. if they are cheap pads like rico or similar brands then malamang yun na yung cause.
    Jan 2003
    i recently had my rear brakes resurfaced and after two sets of rear brake pads, ferodo and rico both are still noisy and the brake dust its very annoying.
    is bendix standard really noise-less and dust less? any other recommended pads?
    Nov 2003
    definitely not dustless but pretty quiet compared to the other brands you mentioned.
    Dec 2007
    Quote Originally Posted by non-vtec View Post
    There's no such thing as a dustless brake pad. The braking process itself requires some dust release at brake friction to avoid juddering of the rotors.
    There are low-dust pads and there are high-dust pads, but no "dustless" pad exists. Be grateful for brake dust, if not for that "annoyance" you may not be able to retard your speed.
    bendix user here, hmm wala naman ako napapansin, kasi kakapalit ko lng, pero nawala ung squeeking sound pag ni-tapak ako sa brakes... update ko toh,
    Jan 2008
    Hi Guys,
    ganyan din nangyari sa corolla ko. yung sakin naman pagmabilis takbo tapos malakas pagkakadiin ko di tumutunog pero pagkamahina lang apak ko sa brakes yun dun sya tumutunog ng "tukutok tukutok." hehe..
    ipinagtataka ko nun kse knowing na sa rapide shaw ko pinagawa yung refacing ng rotors at sa kanila ko na rin pinapalitan ng brakes. ilang beses ko rin sa kanila dinala para maayos pero balik at balik pa rin ang tunog. nagtry din ako sa iba pa shop pero ganun pa rin..
    at sa huling pagkakataon dinala ko uli sya sa rapide shaw(iba na pangalan ngayon) at nakilala ko si mang Benny. ang mekaniko na nakasolb ng aking matagal ng problema. alam nyo ba ginawa nya? nilinis nya rotors at pads ko..
    at yung susi sa pagkakawala ng tunog ay yung maglagay nya ng grasa dun sa.. di ko alam tawag basta yung parang bolt na naghohold ng pads. yun kse yung naglalaro pag umaapak at nagrerelease ka ng preno.
    hay sa wakas nasolve din ang aking "tukutok" problem..
    special thanks to mang BENNY.. ur the man!
    switlaber,
    dude, ung piston ng brake assembly mo yan, e1 ko kung tama pero yan ung pagkakaindinti ko nung problem sa Car ng neighbor ko... kelangan mo na syang palitan, kya nilagyan ng grease, para lng temporarily di mag ingay...
Need Help: Noise in Braking
