Results 1 to 8 of 8
    Apr 2010
    hey guys i'm not sure if i posted at the right thread palipat na lang sa mga mods thanks kasi yung car namin when it reached the speed of 80kph then you stepped on the brakes nagvivibrate siya ng grabe just wondering if brakes ba problem nun? thanks guys!
    Feb 2009
    Quote Originally Posted by the_comet View Post
    as usual, year, make, model, mileage. is the car equipped with anti lock brake system?
    pag nagvivibrake ang steering wheel or brake pedal during braking usually the culprit is warp rotor discs.
    Apr 2010
    chevrolet cassia 2001 model 110,000kms and yes the car is equipped with an ABS and the light is always on
    If the brake light is always on, check the level of the brake fluid in the reservoir. Clean brake pads and shoes, bleed the system and refill with new brake fluid. Visually inspect the rotors to see if they need refacing or replacement (due to warpage).
    Feb 2009
    have the abs scanned for dtc's (diagnostic trouble codes). check the trigger wheels yourself for embedded debris between the teeth of the trigger wheels and sensors for disconnected wiring or damaged sensors themselves. this is usually caused by a mechanical problem
    Apr 2010
    the brake pad has been changed i think last december and the brake fluid is still in the max level so maybe the disc brake is the problem i'll check it if it needs to be replaced
    thanks for your inputs guys!
    same problem with my altis(which is disc front, rear drum) before, about 1 1/2 year ago, my remedy was change all brake pads, clean brake components and flush and bleed brake fluid lines. ayun umayos naman. kapapalit ko lang last 90k km ng brake pads front.
braking problem
