Results 1 to 20 of 97
    Sep 2006
    pano b ilapit yung wheel s wheelwell, yung front wheels k kc parang sobrang layo ng distance s wheelweel ko.
    would it help kung lgyan ko ng rubber yung spring ko s likod, sbi kc nla it would pushdown yung front ng car if do that, tama b
  2. #2
    Try to get lowering springs... also try to do a search, there are several threads regarding this topic
    Aug 2006
    Quote Originally Posted by lightninmcqueen View Post
    you're making it hard for us and for yourself... Hndi ko man lang masabi kung ano ba talaga gusto mo gawin... wheel is wheel, wheelwell is wheelwell... Pano' mo paglalapitin yung dalawa? Kung ibig mo sabihin eh i-lower yung "height" ng sasakyan mo, just say you wanna lower it...
    btw, yung spring mo sa likod hindi pwedeng lagyan ng rubber yon, pero may spring pads na tinatawag... but even if you do that, it'll hardly make a difference to the front's... Magmu-mukha lang mas-mababa kase itutungo mo ng konti... nt a very god idea to me...
    Aug 2004
    The front wheel well of most Japanese Compacts is usually higher up than the rear wheel well to prevent the wheels from hitting the fenders when you hit a bump while the wheels are turned.
    Placing rubber spacers in the rear shocks won't push the weight of the car onto the front springs, it'll just even the gap out.
    A good set of lowering springs is the best option, as they usually lower the car just 1 - 1.5" in the back and 1.5 - 2" in front.
    Sep 2006
    thanks for d info, so mgkano nman usual price ng lowering spring?
    Sep 2006
    branded lowering springs costs in the range of US$150-$200, not to mention that you'll need to get after market struts/shocks to match your lowering springs. as using your OEM struts will just blow in a few weeks.. months.. + camber kit(if applicable) + 4wheel allignment if you are concearned with tire wear..
    Aug 2006
    Quote Originally Posted by GreenThumb View Post
    You can just get lowering springs with low spring rates, somewhere close or just up to 50lbs higher than stock... It's been done countless times and no the shocks won't blow, as long as you don't drive it like you stole it...
    Oct 2003
    Why not get a bigger rims or lowering springs.
    Feb 2005
    niky,
    can you give as recommendation on what brand of a good Lowering spring for Toyota Corolla? I have the same problem din, mas angat ang Harap kesa sa Likod. I'm worried pagbili ng Lowering spring, maybe it will have the same looks na naka-lowered lang, pero mas mababa pa rin sa likod!
    SALAMAT PO!
    Aug 2003
    another way of looking at it..
    is it safe to put, say, 225/60R17's on your typical car? that would definitely reduce the wheel to wheel well distance, and as an added bonus increase ground clearance a bit.
    not too pretty to look at, but.. large rims and thin rubber make the ride bumpy anyway.
    any drawbacks to this? would it cause tire rubbing against the fender liner when turning?
    Aug 2006
    Quote Originally Posted by orly_andico View Post
    I can see alot of body roll. It will rubbed on typical car(i.e. corolla,civic)plus it will messed up your speedometer.and it will look like a tank.
    Aug 2006
    no matte what size of rims you switch to, you have to keep in mind that you need to maintain the overall diameter of the wheel w/tire... you go with bigger rims, you'll have to get tires with shorter sidewalls... that's how it is and it won't make sense doing that just to decrease the wheel gap...
    Aug 2006
    Quote Originally Posted by mikaztro View Post
    that's a no no... not only will it make the car look to be it's worst look, but also will it make the speedo off... oh and it's a more expesive option...
    Oct 2003
    Quote Originally Posted by blink21me View Post
    Is that so? How come other guys put rim 17's in their rides? So you mean to say their ride are in its worst look?
    Yeah, i'm pretty aware that changing your original size of your rim/tyres will change your speedo/odometer readings just like my 4x4 does from 27's tires to 31's.
    Aug 2006
    well bigger rims with bigger tires making the overall diameter 2" bigger - that's what I was referring to if you didn't get that, and that's just my own opinion, you ever thought of that? sorry I forgot to put IMHO in that post...
    then why advice to do the same thing to other person's car???
    Ser, wala tayo sa 4x4ph.com.
    Pero pwede iyan if you want the 'rally racer' look for your car...
    Oct 2003
    Hahaha Otep, I said big rims not big tires.
    Feb 2006
    My two-cents worth. I would guess the original intent of decreasing the wheel-wheel well distance is to improve the look - the "stance" - of the vehicle. In this case, simply lowering the car with aftermarket springs will achieve this purpose. Going to bigger rims with lower profile tires is another matter altogether. I read once that a rule-of thumb for a good "stance" or look to a vehicle's profile is to make sure that the tire's sidewall is thicker than the visible space in the wheel well. That's why cars with low-profile tires look "lifted" when they maintain their stock springs/ suspension height.
distance between wheel and wheel well
