Originally Posted by
LN106G
Ok so you replaced your primary clutch master earlier. Did it solve your spongy pedal before?
Now you just recently replaced your clutch pressure plate, lining, release bearing & clutch slave.. And now you have slipping clutch once you reach operating temp
My guess is that the push rod of either the slave or the primary master is adjusted way too long.. If you still have the old OEM slave take the length of its pushrod & compare it to the new one. Also compare the depth of the depression of the slave piston in relation to the slave vs the old OEM. Once you're pretty sure that your new slave's piston & push rod plays fore & aft is comparable to the OEM, only then that you can adjust your pedal clearance by increments...
That is the little problem you encounter with replacements... Hehe.
