Results 1 to 14 of 14
    May 2019
    Hi, I need help with my 2009 civic.. last night I experience a metal to metal sound at the back of my car, something like a tin can got stucked on my wheel.. Parang nasabit na lata. Then morning, nag try kami na alugin then we got the same sound, may natunog talaga na parang lata. The disk brake has no damage, brakes are working fine, doesn't get the sound when doing brakes.
    May nagsabi po na bushing or bearing? Any idea po what part is giving the issue? Thank you po sa makakatulong.
    Quote Originally Posted by Liana View Post
    a soundbyte recording would have been nice...
    anyways, i really have no idea.
    either the bearing or the brake. or maybe even a furrin object, like a lata!
    but if you say the brake is fine, that leaves the bearing, or the furrin object. although, bearing failure is usually described as a gravel-y sound when the wheel turns. and kung brake naman, the quality of the sound usually changes when the brakes are applied.
    just bring it to the shop, po.
    the issue should be clearly evident when the mekaniko opens it up.
    pretty much straightforward naman yan.
    and i do not envision a very expensive endeavor, naman.
    good luck.
    Jan 2009
    Does it correlate with speed? Road condition? Having or not having passengers and/or cargo in the rear?
    Have you jacked it up and taken off the wheel and do a thorough inspection... outer and inner side of the hub/rotor?
    When were the rear brake pads last replaced? It could be an extremely worn-out brake pad that has broken free from its retainer. It could also be a stuck caliper piston.
    It could also be the wheel bearings giving out. Especially if the vehicle went through deep flood.... water can ingress the wheel bearing seals and basically trash the grease.
    Yes, a recording would be helpful.
    I've seen (heard) something similar before after a brake job. It turned out to be the brake lines coming loose from their retaining clips and rubbing against something, possibly the wheel rim.
    May 2019
    Hi, Sorry for the late respond po, here's the video with the sound. Yan po yung pinaalog ko yung rear tire then my sound sa right wheel, ganyan din po yung sound if naandar at certain turn ng wheel.
    https://streamable.com/x2zg47
    My guess's
    - Fallen shock absorber hitting the coil spring
    - worn exhaust manifold/ muffler baffle
    - disk brake cover
    - or somebody dropped or left a tool hanging
    A quick trip to the lifter should be able to see the underchassis problem
    May 2019
    My guess's
    - disk brake cover
    Thank you po. Noted, hindi ko pa kasi madadala din at delikado po ilabas.. May magchecheck nrin po mmaya
    Jan 2009
    Very likely a loose bolt, worn-out bushing or links.
    Check all the bolts/bushings/ball joints around the knuckle assembly, including the stabilizer links, etc. The fact that the noise can be replicated by just shaking the tire by hand, says that the loose part isn't weighted down as much by the vehicle.
    But this is probably not something you want to fix yourself so have it serviced professionally, is what my recommendation is.
    Here's an interesting look of the rear suspension in action.
    like the others, it sounds like a loose mounting bolt or degraded rubber bushing that has fallen off.
    if you are not averse to lying down under your car and getting your back / shirt, hands and hair dirtied,
    you can lie down under the car and hand-tighten or wretch-tighten the loose culprit.
    then you can drive leisurely over to the talyer for a good look-see, for other issues.
    if it's a degraded bushing, it probably won't get much worse along the way.
    good luck.
    May 2019
    The culprit was the rear wheel hub bearing! When the hub is turned, doon po nalabas ung tunog.. Okay na po siya. Though, I didn't expect the price of the hub bearing. Ang mahal pala, around 2k ang isa.
    Super thank you po sa mga inputs! Will be back, I can feel na maglalabas na talaga ang mga sira since the mechanic told me that my bushings, ball-joint are already worned out and needing replacement..
    Jan 2009
    Yepp, nagpalit din ako ng rear hub bearings sa FD ko before. But in my case, it's a subtle "rrrrrr" rumbling sound that coincided with the vehicle speed. It's a common problem, especially if the vehicle had been through floods at inabot yung bearings.
    Kaya nga, maraming mga tao ang lakas ng loob lumusong sa baha, thinking na basta hindi umabot sa intake, ok lang sila. Di nila alam na in many cases, pinapasukan ng tubig mga pang-ilalim na joints, bushings, at bearings. This is especially true kung biyak na yung mga rubber boots and whatnots. Once water gets to the grease or lubricant, bilang na araw nung part na yun.
    bearing prices certainly have gone thru the roof...
    from a few hundred bucks for a japanese brand, to about a thousing for a german or scandinavian brand, back in the day...
    Jan 2009
    The rear hubs on the FD are assemblies, with the bearing built-in. I don't think you can practically replace just the bearings without destroying the hub itself. Kaya mahal.
    Feb 2024
    Yup, they are assemblies so you can't just replace the bearings. So more expensive.
Metal to metal sound on my 2009 Civic rear wheel
