Results 1 to 10 of 16
- Jan 2009
- 24
January 31st, 2009 08:05 AM #1bago po ako member dito, tungkol po sana don sa ingay ng van ko. pagnagturn po ako ng left tapos di pantay (kasi po un daanan going to school ng anak ko mattas un rampa) may ingay po ako naririnig.
even po sa may humps kasi sa village din meron hump na mataas. Napapansin ko po eto lalo na pagdipantay ang gulong (dinadaanan ng gulong)
- Jan 2009
- 24
- Jan 2009
- 24
January 31st, 2009 11:17 AM #5
WHAT KIND OF NOISE?
Like metal to metal noise?
Clangking noise?
Rubbing noise?
Or noise from suspension (shocks) when you hit the bump (hump).
For safety reason can you check the balljoint. Maybe it wear out prematurely and if that things happen and the front wheels fall off the car this is the case it would be a very bad thing to happen as you drive. Again, just for safety reason, do it even though its not.
- Jan 2009
- 24
January 31st, 2009 11:29 AM #6its inggggk sound(short lang namana) sorry im new in driving too. . . pero i keep asking people around who know who to drive and had van too - naramdan din nila when i asked them to drive it un pero no clear answer from them
- Jan 2009
- 24
January 31st, 2009 11:35 AM #7FYI abt my ride
JAPAN surplus po - MAZDA MPV
last jan 2 pinapalitan namin un assembly (rack n pinion) para mawala un leak ng ATF. Palit kmi din ng hose and tube
then we heard parang something wrong sa liko sabi don sa MP2 manipis ng un rubber sa strat bar - so hanap (mahal pa rebosing jan sta mesa) good i found here in Paliparan may gumagawa ng rebosing
Now, nga un sound nga somewhere s likod.
hayyy naku - good ride pa naman siya talagavery smooth even long driving wag lang liliko tapos mataas
January 31st, 2009 11:49 AM #8
Check the suspension.
Shocks on your van are to keep the springs from bouncing up and down too much. It is an important part of your suspension system. Bad shocks don't make noise unless you hit a bump. Check if you can see a fluid leaking from the shock or push down one corner either the bumper or the hood as hard as you can then release, and if it bounces back up more than twice you should get them checked out and replaced them w/ new one.
- Jan 2009
- 24
January 31st, 2009 12:09 PM #9okay check ko mamaya di kasi makalabas mainit don lugar niya ehh. Anyway salamat
- Jan 2009
- 24
February 4th, 2009 07:41 PM #10sir v6 dreamer nacheck ko na po at pinacheck ko din po sa mekaniko sabi niya wala na daw inuupuan un shock spring po ba un (spiral style - sori medyo di me know sa parts - newbie pa) tapos kung papalitan he ask 1200 bawat isa - sa banawe ko po un tinanong kasi may backjob un gumawa ng rack n pinion ko po - kasi po pinalitan ko po un buong assembly - dahil tumutulo po un atf - tagal po ako pabalik balik don kasi un unang gumawa un w_______ mekaniko (inubos lang iyong budget ko) so kahapon bale inayos po nila un pinaglalagyan ni assembly kasi nga po maluwag tapos ngayon naman nawala naman yong busina ko. pagpinihit ko po ng pakanan may busina, pagsentro at pakaliwa wala. Grabe po medyo stress out na po ako kasi pinagawa ko po dito sa cavite sa layo ng banawe - ginawa nila - tapos gumana na after grocery pick-up ko un anak ko school ayon pinihit ko lang ng malaki sa kanan - hay wala na akong busina - tinawagan ko un gumawa dito sa amin para malaman nila pero sa sobrang pagod ko na mula kahapon i feel exhausted na . Hirap po ba talagang gumamit ng JDM - 1 year pa lang po siya sa akin pero dahil daw converted nga daw (as mekaniko said) maraming bumibigay hmmmmmmmmm....... May nagsuggest po sa akin na idirekta nalang daw pero sa manibela pa rin ang busina tama po ba yon? Xencia na po sa abala
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
