Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    they are offering this rebonding service, instead of buying new brake pads for ur shoes, they'll rebond it while u wait. iba daw ang materials na gamit nila. rubberized daw, or something . has any one tried this service of theirs ?
    I don't recommend rebonding of brakes, not safe, IMO.
    Magkano na lang naman ang brakepads, mura lang naman, sigurado ka pa.
    Bendix is okay.
    some of our members have rebonded brakepads on their REAR disk brakes since walang available na pads para dun. oks lang naman. kung pang front, replace na lang siguro
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    there were cases that the material got detached from the metal.... service warranties are useless once you've met an accident due to this... be safe than sorry... this is one part that shouldn't be compromised...
    unless proven na ang system ng gumagawa...
    thanks alot sa mga replies , bro!
    Nov 2003
    get bendix nalang. price isn't far off and you'll be safer in the long run.
    Feb 2005
    correct me if im wrong na lang pero di ba yung mga original na brake pads eh naka bond lang din?
    i will, can someone tell me where to buy original bendix brake pads for rear wheel drive applications ?
    Sep 2004
    magkano na ba ngayon mag pa rebond ng drum brakes sa likod?
    Aug 2005
    tol breaks yan wag mo maliitin yan.. rebonding kung wla na talagan budget.. bili ka nlang yung set na bago.. pag rebonding pwde rin matangal while breaking at hindi pantay yung kain ng brake drums.. sakit pa ng ulo mo diba? bili ka nlang bago wla pang problema.. hehehe..
    Aug 2005
    rebonding less than 500 petot.
    Dec 2003
    brandnew bendix pads are just P500-900+ depending on the car, san ka pa?
    Sep 2004
    Quote Originally Posted by BlueBimmer
    kahit drum brakes? 500-900 / pair?
    Dec 2003
    sa drumbrakes not bendix pero nasa ganyan din ang price
    If you want something cheaper, buy R-Spec instead. They are around 400 or so only. Downside is less stopping power, but definitely surer than brake rebonding.
    Aug 2005
    mine still orig but mga 1 yr nlang gamit n2 palitan ko na ng bago... sa friend ko na may ari ng shop di talaga advisable rebonding.
    Nov 2003
    if you can't spend the 1k+/- for good brakes you don't deserve to own a car. you're endangering yourself and others driving around you.
    ok lang magtipid kayo pero sana naman nasa tamang lugar.
    Ok lang ipa-Cruven ang suspension. Pero kung brakes ang usapan, just get new pads. Bendix is not that expensive. Yan ang gamit namin for almost the whole fleet with no problems whatsoever. For brake shoes, minsan mahirap talaga maghanap ng replacement. At least the rear brakes only carry about 20% of the load.
    bendix is decent. pero maingay! ilang weeks pa lang, maingay na agad. hmph. same thing happened with my last pads which was(were?) also bendix, i experienced less noise when i used r-spec but, gaya ng sabi sa taas, medyo mahina performance.
    Apr 2004
    i tried RICO replacement pads, cheaper around 300 lang, mukhang ok naman..
m7's brake pads rebonding
