Results 1 to 17 of 17
    pudpod yung front tires of ng patrol ko. ano kayang problema since wala naman camber correction ito?
    Signature
    Could be the alignment... happened on my Frontier before, kala ko walang problem sa aligment since walang kabig then when i inspected the inside of the tires ubos na. Turns out the tires were not facing the same direction (toe adjustment was set in too much... baka sa yo naka toe-out pareho).
    Oct 2005
    toe out yan.
    may toe-in toe-out din ba kahit solid diffs ang harap?
    Signature
    Jun 2004
    I assume you're comparing the tread wear of your front tires with the ones at the rear. If yes then it may be due to the fact that mas mabigat ang front end due to the weight of the engine. So over a longer period of time the tread wear up front will be greater than that of the rear tires (especially if you rarely carry a full load).
    If di pantay ang kain ng tires then a wheel alignment may be in order.
    Jun 2004
    Ooops di ko nabasa ng mabuti yung title nung thread. Mas pudpod pala yung outer part ng tires...
    Quote Originally Posted by paj4x4
    hehe, so does your previous post still hold true?
    Signature
    From what i know (based sa Safari and LC80 dati) sa front the camber cannot be moved anymore but with the aligment this is still adjustable.
    should i feel anything different in this condition, like steering wheel vibrations, etc.? pero wala kasi akong nafi-feel ngayon. actually, i had my tires rotated last month kasabay ng alignment, but lately ko lang napansin yung pudpod sa rear tires, which were the front tires before being rotated.
    also, napansin din ng friends ko yesterday na medyo tabingi yung right front tires, parang naka toe-in (mas pasok yung sa lower side).
    Signature
    Sep 2005
    sir,
    check your upper and lower knuckle bearings
    front hub bearings
    tie rod ends
    andun lang ang problem mo sir baka maluwag lang or kailangan palitan
    mas madali sa straight axle kaysa sa IFS. alignment lang. walang camber at caster adjustments.
    toe in toe out lang siguro. also check your tire pressure. usual namn sa front tires outer ang unang pudpud since it turns and scrubs.
    Quote Originally Posted by ARB
    sa alignment ba yung toe in toe out? akala ko kasi sa camber yun.
    Signature
    Sep 2005
    alignment iyan sir.
    Quote Originally Posted by boybi
    Yup.
    I had the same experience with my big vehicle (diesel engine). 30psi lang kasi ang karga ko sa gulong para softer ang ride. I have now switched to 38psi and it looks like the issue is resolved. Mas matalbog lang talaga...
    Jul 2003
    Sa akin naman mas pudpud ang inner parts ng tires, ball joint kaya ang defective
    Jan 2004
    acenie,baka naka-negative camber yung front tires mo...
Mas pudpod ang outer parts ng tires
