Results 1 to 11 of 11
    lost the key of my wheel lock. ive got a flat tire, di ko maalis.
    would somebody pls help me. where could i find a key or pano ba maalis to na wala yung key....
    any help on getting the wheel lock off would be greatly appreciated
    pls click the link for the pic of the wheel lock
    http://www.flickr.com/photos/dennisbonoan/3761351783/
    http://www.flickr.com/photos/dennisbonoan/3762150762/
    http://www.flickr.com/photos/dennisbonoan/3761347377/
    http://www.flickr.com/photos/dennisbonoan/3762147206/
    http://www.flickr.com/photos/dennisbonoan/3762144350/
    Apr 2009
    padala niyo po sa mismong shop po kaya? alam ko po me equipments sila pang tanggal as long as mapatunayan mo po na ikaw ang may ari:D
    Jul 2003
    you need this type of socket or you can try to improvise one
    http://ecx.images-amazon.com/images/...8L._SL160_.jpg
    Feb 2009
    Quote Originally Posted by speedfire View Post
    speedfire,
    since you lost the key to your wheels already, you will have to remove all four locks before you get into a predicament of having another tire problem while on the road. the least damage done is to drill the stud bolt of the wheel where the locks are at the center along its axis to almost the diameter of the bolt ( the bolt looks like a regular 12 mmX1.25) and replace all the four stud bolts from where the locks were removed. start with a small drill bit first, then work your way up. this way, you will save the aluminum wheel ( costlier than the stud bolts).
    jick
    simple lang yan pero kailangan mo i tow sa shop yan
    what i usually do is find a 19mm nut and weld it with the wheel lock nut .
    the best if the shop is equipped with a MIG WELDER.
    Feb 2009
    Quote Originally Posted by bambino View Post
    bambino,
    this suggestion has a bigger risk of warping the brake drum or rotor from the heat of welding not to mention the weld spatter to the aluminum wheels. if you will have to tow it to the shop, they usually have at least an electric power drill. this operation does not generate heat high enough to damage the brake components. just drill the stud bolt out or use a wheel lock nut socket if available ( this tool is used in conjunction with a pneumatic impact wrench, industrial finish, threaded tapered counterclockwise and grips the lock nut), usually available at NAPA auto parts. the last time i heard, there is one NAPA parts store in manila.
    jick
    jick, i've done it so many times in my shop and i never had any problems to this procedure .
    besides, i'm saving the owner labour and parts .
    just imagine drilling and changing the studs alone cost the owner alot of money specially if the hub assy requires removal just to change the stud.
    if you never have done it don't do it ,but if you wanna try ,make sure you know the procedure,AND YOU WILL BE SURPRISED IT ONLY TAKES 10 MINUTES OF YOUR TIME TO DO THIS .
    bambino
    CLASS A LICENSED AUTO TECH
    CLASS A LICENSED TRUCK TECH
    CERTIFIED A/C TECH
    CERTIFIED AUTO ELECTRICAL TECH
    TECHNICAL ADVISER TO THE INDEPENDENT SHOPS
    AND DEALERSHIPS
    ALTERNATOR AND STARTER REBUILDER
    AUTOMOTIVE ELECTRONICS SPECIALIST
    EFI DIAGNOSTICS SPECIALIST
    SHOP OWNER ,TECHNICIAN
    thank you all for the reply....
    been to a servitek shop kanina lang, naalis na ung lugnut
    ang ginawa ipinalo (4x) ung socket sa lugnut pumasok naman, ayun naalis ung apat na wheel lock.
    la kayang magiging problema dun sa ginawang pagpalo???
    Ok lang iyan. The wheel experiences more force during your daily drives.
    Aug 2006
    Bambino's approach is better than drilling the stud bolt. My late father use this approach in few cases. TS can inflate again the tire (if Tubeless) with foot pump or portable cigarette lighter powered pump and he can drive it to nearest machine shop, in Manila there's always one on any major street or community.
    But if the TS can't tow or bring the car to the shop, he can just buy again one set of wheel locks with key (P500) from any car accessory shop, got mine at Evangelista. From the picture I think it was a Toyota Type R and I have one installed in my Innova (I do always carry the key in the ash tray compartment).
    TS can also use chisel to loosen the nut, there's enough space to chisel it, but to be safe in avoiding accidental damage to the mags, he can also use a #21 or if not #22 crown socket and force fit it to the nut.
    Jun 2003
    Hi,
    Buhayin ko lang itong thread.
    I lost my key/adaptor for the wheel lock. Balak ko sana i-force ang socket kaso alanganin ang size nya, meron ba kayong recommend na shop to weld a nut? or if meron pong ibang paraan. Or baka meron po kayong alam na shop na madaming tinitinda na wheel lock, naghahanap din kasi ako nung kaparehas ng sa akin kaso wala ako makita.
    TIA!
lost key for wheel lock.... help!!!
