Results 1 to 10 of 10
    Oct 2004
    mga sir ano maramdaman pag may crack na suspension bushing,left and right,front.usually how much parts and labor nito?galing kc ako sa mechanic for wheel alignmnt kaso sabi pagawa mmuna raw bushing bago alignment.tnx
    mura lang ang rubber bushing at labor. pag sira na yung bushing may maririnig ka either TOK sound or grinding steel sound parang umi-itit. ang ipalit mong bushing yung polyurethane type para mas tumagal.
    ^^eh kung rear bushings ang may problema, ano simtomas nito?
    Sometimes there are no symptoms or tell-tale signs of worn/cracked bushings. Anyways, you can just crawl under the vehicle and visually check the bushings' condition.
    ^^how much would it cost to replace them (civic '96 vti)?
    ano nga ba effect nito kapag matagal di napalitan ang mga bushing?
    Feb 2006
    Quote Originally Posted by baludoy
    Kung trail arm bushing ng civic (based on experience), go for the OEM (around P1,200 each -- price last year) kase kung mga replacement bushings (costs P500 & up), hindi tumatagal. Less than a year bumibigay na, so you would end up spending more sa labor (medyo matrabaho kase kailangan kalasin ang brake line). Yung pag palit ng bushing, have it pressed kase pag pinupuk-pok, nasisira yung butas kung saan pinapasok ang bushing.
    So kung palit ka:
    P1,200 x 2 = 2,400 - Bushing
    P 100 x 2 = 200 - Pressing
    P 500 x 2 = 1,000 - Labor (depends on the shop)
    Other suspension parts would follow.
    mura lang bushing!
    nasa P300 pataas.
    Oct 2004
    tnx guys
    Nov 2003
    bushing price depends on the size. plus pressing when needed and labor.
    pomelo says:
    ah kaya pala nabanggit sa akin dati na kelangan pa daw ipa-machine shop pag replace ako ng rear suspension bushings
suspension bushing
