Results 1 to 20 of 22
    Jul 2014
    guys, help po, pa-locate kung my thread na po para dito sa problem ko. My encountered lagatok ako kapag na-break po ako. kapapalit ko lang din ng tie rod, rack end and stabilizer, pero same pa din. kapag mabilis takbo wala nman lagatok kapag na-break pero kapag slowdown like trafffic don ko lagi nadidinig ung lagatok sa break. pwede po kaya malaman ano pa other issues? 5 yrs car unit honda brio 1st gen owner.
    salamat po ng marami.
    Quote Originally Posted by bokswager View Post
    may lagatok na ba, before you replaced your tie rod, rack end and stabilizer?
    if the lagatok appeared only after the replacement, then you have your answer.
    is it possible, the sound has nothing to do with the suspension and steering system, but with the power train or engine support?
    Jul 2014
    meron ng lagatok before ko po pinalitan mga parts, still andon pa din po ung lagatok kapag napreno after replacing don 3 parts sa front.
    engine support?
    brake caliper not installed properly after baklas?
    brake pad na manipis?
    btw mabilis or mabagal nalabas yun lagutok?
    Jul 2014
    engine support?
    pina-check ko din po brake pad sabi skin makapal pa din, pina brake cleaning ko na din ganon pa din.
    paano po ba checking sa engine support?
    kapag mabagal lang po, my lagutok,my tug-tug na sound po kpg pinepreno ko.
    sabi sakin ung shock mounting ko kailanga na daw palitan. hindi ko sure kung related un sa lagatok kapag na-break . any thoughts po.
    Jul 2013
    hmmm... angat mo yung tire tapos try mo igalaw yunbg tire...
    left right tapos up and down... try mo pakiramdaman
    Apr 2014
    Seek second opinion.
    Wag na don sa unang pinagpagawaan mo.
    My wild wild guess. Warped rotor or sticky brakes.
    But it could be anything since we can only speculate sa forums.
    Aug 2009
    Brake pad. Yung innova ko dati ganyan problem nung pinalitan ko ng replacement na brake pads. Nung binilhan ko ng OEM, back to normal na.
    Jul 2014
    Quote Originally Posted by chronicle View Post
    pero sir wala akong experience vibration sa wheel kung warped rotor po. tska po sa mga turns ok naman po, no issues of any wiggle kahit mabilis po sa hiway. un nga lang po kapag mabagal na takbo nya my tug-tug na sound kapag mag brake na.
    Jul 2014
    ngyon ko lang narealized na mali pala spelling ng brake ko. hahaha. thanks guys, papa diagnoese ko nlng sa shop ung problem, atleast my idea na ko ano ano papacheck ko sa auto.
lagatok sa break
