Results 1 to 4 of 4
    Apr 2008
    mga paps,
    have this problem going on for the past 5 days. yung lagatok nangyayari lang kapag napahinga yung kotse ng matagal. usually sa umaga bago pumasok sa trabaho at sa hapon bago umuwi. from still position, 1st gear then andar ng konti... tapos ayun... may isang lagatok. pero after nun wala na. kahit i-try ko na tumigil for 15-20 mins with engine on and engine off... hindi na ito nauulit. help naman mga paps para bago ko ipa-check sa talyer at least my idea ako.
    tapos yung brakes ko may squealing sound. meron din itong sound na parang mga lumang kahoy. yung bang parang sa mga galeons nung spanish era (based sa sound effects ng master & commander... hehehe). anyway, ang ginawa ko so far are the following:
    1. overhaul/ linis ng caliper
    2. palit ng rotor discs at pads
    3. alignment ng gulong
    unfortunately, nandun pa din. pag malamig ok lang, pero mag maiinit na ayan na ang nakakairitang tunog.
    help naman mga gurus. TIA
    Dec 2007
    Quote Originally Posted by emersonc View Post
    mga paps,
    Yung sa 1st gear na lagutok, baka dumidikit dahil sa hand brake (I'm assuming you use it). Nangyari na rin sa pickup ko yan, eh.
    Yun namang squealing sound, hindi siguro nag-re-retract nang maayos yung pads, kaya naka-touch pa rin, hence the sound.
    HTH...
    Jul 2006
    baka yung lagatok sound mo yung ndi lang lapat na caliper or pads
    possible din sa stablink mo "tok" ba yung sound?
    yung gralgal habang umaandar ka yung sa likod na brakes mo baka need replacement na
    May 2007
    I think your piston brake is causing the problem and its about time to rebuilt that brake caliper. Rebuilding a brake caliper does'nt mean stuff like machining or hone part its just a simple matter of thoroughly cleaning parts and replacing inner o-ring and dust cover, and of course plushing the whole brake system too. Its a straight forward sense, its time to give an attention your brake.
lagatok at ingay sa brakes
