Page 1 of 2 12 LastLast
Results 1 to 20 of 56
    Apr 2005
    ano po ba recommended brand ninyo? tia
    Jan 2003
    tried powerplus before, ok naman. its a good alternative to refacing. around 1k plus each for a normal sedan.
    Jul 2006
    Be sure to replace both at the same time.
    Apr 2005
    thanks guys! heto na-canvass ko:
    powerplus 2,400.00
    federal 1,900.00
    taiwan-made 1,100.00
    per set yan. suggestion din mekaniko palit brake pads, bendix.
    ^^^ Bendix is one of the most recommended, ok yan :thumbup:
    Nov 2003
    powerplus is better than the generic taiwan ones imo
    Jan 2003
    whoa! nagtaas na siguro yung powerplus. before, around 1.5k lang kuha ko.
    aside from what mbeige said, you have to install new pads as well para sure ka na walang magiging problem.
    on a sidenote, are there any shops who can properly bed-in new brake pads? can it be done while the car is on a hoist?
    i read the instructions about the brake pads that i bought but there's no place here in manila where you can run properly bed-in the pads.
    Jul 2006
    What's "bed-in"?
    powerplus 2,400.00
    federal 1,900.00
    Gaaano kaya kalayo quality ng powerplus vs oem?
    Btw may idea kayo magkano rotor ng bendix pag pair na?
    ninjababez online
    ninjababez online
    I've used replacements (power plus and generic) before and they all performed okay. Never warped unlike the OEM Toyota rotors they replaced (Hiace, Altis, Vios)
    ninjababez online
    Walang wenta yung powerplus, twice ako nagpa reface in 2years time. Im now using Bendix rotor nasa 1,500/pc pang Altis.
    Sent from my SM-N9208 using Tsikot Forums mobile app
    mga sir ant idea kung magkano ung power plus rotor disc for isuzu bighorn (trooper). San po kaya meron tinda ganito?
    Tnx
    Nakapagtaka puro pag machine shop ng rotor recommendation ng mga talyer na nadaanan ko, tapos 1k to 1.5k ang charge. Pwede naman pala bumili ng bago.
    ninjababez online
    ninjababez online
    because it's easy money for them, po!
    they'll charge you 1.5 K for it, when it really costs only 700 bucks.
    errr... how much does a new rotor cost, po?
    From 2k - 10k (oem)
    ninjababez online
    From 2k - 10k (oem)
    ninjababez online
    up to 10K !
    hindi na'ko magtataka, kung bakit re-face na lang.
    ninjababez online
    Kung malaki & makapal pa and may grooves na yung rotor bro it makes sense to have it refaced. Mahal kasi, sa PPVs around 10K up ang oem. Sa maliliit it makes more sense to replace, halos same na kasi ng cost ng reface yung replacement.
    mga bros
    power plus vs hiq brake rotors
    ano ma recommend nyo?
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    Taiwan ba yung Power Plus then Korea yung HiQ sourced from China? Doon ako sa democratic China, parehong manipis at non-ventilated(solid) rotors yata but they will do just fine on regular use.
    not sure bro
    wala ako makita online na info about powerplus
    opted for safer choice nalang which is yun hiQ
replacement rotor disc
