Results 1 to 10 of 17
- Aug 2006
- 21
July 1st, 2007 10:52 PM #1help mga tol... nakakainis kasi yung tunog, at the same time, may mga itim nanamumuo sa mags ko... nililinis ko sya madalas, then may nangingitim uli... mukhang dun yun galing sa brakes e... any idea what part ng brakes yun??? tnx... btw... disk brake sya, toyota gli, sa harap na gulong... tnx...
July 1st, 2007 11:07 PM #2
Check your brake pads immediately!
Pag hindi mo agapan baka madali rotor disk mo!
Zombie
- Aug 2006
- 728
July 2nd, 2007 07:46 AM #3brake pads yan hijo. nakapadelikado nyan sa buhay mo at ng mga kasakay mo.
papalitan mo na kagad, mura lang naman yan. ipa-reface mo ren ang brake discs mo dahil mukhang marami nang nakain at siguradong di na pantay yan.
isabay mo na ren ipa-check yung rear drums mo, malamang kelangan na i-adjust yan.
- Aug 2006
- 21
July 2nd, 2007 09:15 AM #4yun nga yung iniisip ko and pinachek ko, makapal pa sya e... any more ideas??
- Mar 2005
- 354
July 2nd, 2007 09:36 AM #5replacement or OEM ung brake pads? ung ibang replacement kc eh umiingay talaga khit makapal pa. bendix ckin eh ok. walang ingay. Nung iba nilagay kc out of stock ung bendix eh ang ingay. nakakainis. kailangang linisin/lihain palagi.
July 2nd, 2007 10:00 AM #6
have that checked immediately if you still have any pads remaining. and you might have damaged discs as well.
also, there's also a slight chance na kaya maingay yan kasi:
- Bendix yung replacement pad na kinabit (squeaky yung iba)
- madumi
July 2nd, 2007 10:04 AM #7
Try to check the disk guard plate baka nabingkong or may stuck na bato.
How is the condition of your rotor?
When did you last replaced your pads?Last edited by 4JGtootsie; July 2nd, 2007 at 10:08 AM.
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 3rd, 2007 10:57 PM #9
since i got hold of my rav 04, as i start my car and move back squeeking sound is heard but after backing ok na, yung una lang weird, nothing seems to be wrong naman
- Jul 2006
- 37
July 16th, 2007 12:25 AM #10This irritating sound also bothers me.
The thing is that all of my pads are still ok.
I will try to clean it via sand paper and will give you guys feedback with the results.
Nawa'y patnubayan tayo ng MAYKAPAL sa ating paglalakbay.
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
