Results 1 to 11 of 11
    Oct 2013
    4 months na po yung tsikot namin simula namin nbili na 2nd hand. Napansin ko lang po ngayon na hindi pala pantay yung pagka pudpud ng gulong sa likoran. Nalaman ko ito nung ibyenahe ko sa malayo kasi maingay pag nasa espalto. Kailangan ba ito e alignment?
    Posted via Tsikot Mobile App
    Quote Originally Posted by jhunter View Post
    ano kayang kotse, year and model.
    depende kasi yan Sir.
    Oct 2013
    Quote Originally Posted by brainmafia_310 View Post
    Isuzu trooper surplus 1992 model.
    Oct 2013
    Hindi kaya nilipat ng dating owner yung tire from front to rear. Dba front lang naman yung e alignment?
    sir not sure with Isuzu Trooper, pero sa kotse alam ko may alignment din ang likod ng civic, altis,.
    pero as far as i know, yun ganayang kalaki na vehicle may adjustment din alignment sa likod. wait tayo feedback ng expert sa isuzu trooper Sir. sorry po di ako makapaginput.
    Aug 2004
    Can you describe how the wear is not even?
    Hindi pantay ang kanan at kaliwa?
    Hindi pantay ang loob at labas ng tire?
    If it's the first, it might be the tires themselves, or you could have a busted shock which is putting more stress and causing more wear on one tire.
    Or if the wear on the tire itself is unusual, it could be an alignment problem.
    If both tires are worn on the outside, then those tires came from the front and were rotated back. Nothing unusual. If both are worn on the inside, then you should check the alignment.
    Oct 2013
    Both tire are worn outside. Ok lang ba ito e byahe ng malayo?
    Sent from Tsikot Car Forums mobile app
    Jun 2013
    pwede din namang sobra or kulang lang ang hangin sir
    Dec 2009
    kung hindi independent suspension ang likod, mostly axle type walang alignment needed...
    pero kung IFS ang likod its could be aligned...
    if im not mistaken trooper is coil harap at likod and solid axle and likod, so no need na align likod.
    correct tire pressure mo muna sir...
    tama comments sa taas, pwede galing yan sa harap nilipat sa likod...
    if you want definitive answers and peace of mind pa check mo alignment sa shops...
    Oct 2013
    Thank you mga sir sa mga inputs.
    May 2012
    ung civic ko sa likod ang alignment. try mo muna magpa camber alignment sir
Rear tire hindi pantay ang pudpud.
