Results 1 to 20 of 20
    Feb 2007
    my car is an isuzu xto. i changed tires recently due to uneven tire wear, as suggested, i have to bring my car for a wheel alignment. wheels were realigned but to my dismay, it sways to the right. i brought it back to the same service center. but still the same, kabig sa kanan. i decided to bring it to other shop, the mechanic there suggested that i should change upper ball joint and tie rod ends. but still the same, kabig sa kanan. naiinis na talag ako dito, balance naman daw ang alignment. but i want walang kabig. any suggestions or possible reasons why kabig pa rin sa kanan?
    Nov 2007
    hmm.. ganyan din sakit ng saaskyan ko pero wheel camber po ginawa at okay na ulit cya, im not sure pero magkaiba ata wheel alignment sa wheel camber
    antayin na lang natin opinion ng mga guru dito
    Dec 2007
    Make sure na halos patag ang daan, madalas kasi sa mga daan natin, pakanan ang declivity para sa tubig-ulan (yata)...
    Ang camber, iyun ang measure ng pagka-PERPENDICULAR ng gulong sa kalsada.
    Better yet, read up on alignment here:
    http://www.ozebiz.com.au/racetech/theory/align.html
    HTH!
    dapat pina camber correction mo muna then wheel alignment then wheel balancing para sigurado.
    check mo din preno mo.
    napa check mo na ba ang pangilalim mo kasi kaya ka merong uneven wear sa tires merong sira na part dito. pagsiguradong naayos na lahat then thats the time palit kana ng gulong and pa wheel balance and alignment.
    Nov 2003
    baka nga naman kelangan na palitan yung parts na yun. why not follow their advice.
    Jan 2008
    Quote Originally Posted by snowbound View Post
    if alignment is OK your suspension is in need of CAMBER / CASTER adjustment but for your case "na may kabig" it would require CASTER adjustment but before doing this have your torsion bar bushings replaced.. adjustments should be made in small increments as this may damage you suspension arm
kabig sa kanan
