Results 1 to 7 of 7
    Mga bro ano ba ang usual na sira pag ka preno merong kabig sa right ng kaunti, pero pag tumatakbo naman straiht lang ito.?
    Quote Originally Posted by raine View Post
    Suspension I think.
    Maybe the ball joint or other bushings in your right side suspension is worn out and needs replacing.
    Apr 2009
    hi.. yung sa akin naman may kaunting kabig sa kaliwa. pag sagad bwelto paatras
    may tumutunog. ano kaya trouble? bushing kaya?
    Quote Originally Posted by anthon05 View Post
    CV joint might be worn out and might need replacing.
    Apr 2009
    pasensiya na dami akong question.. my ride si crosswind.
    ano yung CV? and more or less how much.
    thanks
    thanks
    CV joint is a "constant velocity" joint. Normally found on front axels of FWD cars. Since your car is a Crosswind, just toss my previous suggestion out.
    Have you checked your wheel bearings for wear?
    nagpaayos ako kanina ng brakes due maingay, nag nasa lifter na pinaikot ang gulong medyo maganit na sabit ang preno kaya pina baklas ko na ang front na preno, linis ang piston, then bleed ang brakes, after that okey na ang gulong,
    pinatingin ko rin kung meron nang problema sa pang ilalim, sa right side merong konting play ang tie rod. thanks GH
kabig
