Results 1 to 10 of 15
- Feb 2006
- 36
March 10th, 2006 04:42 PM #1hello people! tanong ko lang sana kung ok lang pa convert na car ko to power steering (96 lancer EL) and kung okey magkano and san maganda pagawa. I live in makati area. thanks!
March 10th, 2006 05:09 PM #2
pwede. price depends on kung brand new or surplus ang ikakabit mo. pag surplus ask ka sa banawe, blumentrit, etc. sabihin mo lang car model alam na nila kung no ibibigay sa iyo. better yet just phone, nasa yellow pages din naman mga surplus shops. some will even install it for you. wala ako alam sa prices pero madami ako nakikita surplus nyan.
- Feb 2006
- 36
March 11th, 2006 03:27 PM #3is it ok to just buy a new engine (with power steering) then just replace my old one instead of converting it to power steering? hopw much kaya yun?
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 12th, 2006 12:27 PM #4the steering system is totally different from the engine. pag bumili ka makina di kasama yung steering rack unless you buy a front cut, in which case the steering rack is normally RHD
March 12th, 2006 09:38 PM #5
A power steering upgrade could cost you from 15 to 20k. Usually bolt on lang ito if you find the right pump and gearbox for your Lancer. With a new engine the only thing you could get is the PS pump that is mounted on it.
March 12th, 2006 11:10 PM #6
Power steering conversion for a Nissan Sentra 1.4JX ('94 B13) will cost Php23k as per quoted by afrasay's cousin (Ferdie). All brand new parts iyan and the quote is all-in (parts, labor, materials).
You can try your luck finding your own parts (e.g. surplus) for the project. This will help lower costs.
- Feb 2006
- 36
March 13th, 2006 03:42 PM #7Originally Posted by OTEP
March 14th, 2006 10:27 PM #8
Hindi ko pa pinapaconvert. Kasi hindi pa decided kung papalitan na lang yung buong sasakyan instead. Sa shop ni Mr. Ferdie Francisco iyan. Pinsan ni afrasay. Ang breakdown niya ay:
*Rack and pinion 12,500.00
*Hydraulic lines and plumbing 3,500.00
*Labor 3,000.00
*Dagdag ka na lang ng konti for other odds and ends you might need
Do take note that prices for the parts might differ per vehicle. And depending on the degree of difficulty, pati yung labor charge pwede mag-iba.
Tawagan mo na lang siya. 023603268 and 09207514323. Sabihin mo referred ka ni Otep Rivera from Martinez Hospital. Caloocan area nga pala siya. And you might need a map to find his shop.
- Nov 2003
- 3,849
March 15th, 2006 10:45 AM #10
i had mine converted, spent about 10 thou inclusive of labor. Corolla 91, 3500 ang steering kit, pump at 1200, hose 1000, 2500 labor(may added work ) so mura na, belt, oil, steering wheel cover sa may firewall sa ilalim $8= 400 petot. dun sa 10 thousand nagpalit na rin ako ng engine support para isang trabaho na lang, so it must be less pala
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
