Results 1 to 9 of 9
    Jan 2011
    My car is civic sedan 96. Need your advice sir kung tuwing kelan ako dapat naglalagay ng PS fluid sa reservoir and tanong na din kung pano ko masisigurado na walang leak ang power steering rack ko? Maraming salamat mga sir :D
    Quote Originally Posted by JayCivic View Post
    Assuming your PS system has no leak, you shouldn't be re-filling your power steering fluid at all.
    Only way to know is to have it checked. If the mechanic sees the steering rack to be wet at certain points, it's safe to assume to have a leak.
    Jan 2011
    Thanks sir. San po kaya okay mag pa check na mechanic? Any suggestion? QC area po sana
    Speedlab - Quezon Ave (across Pegasus)
    Jan 2011
    Small time lang ako sir. San pa pwede? hehe. Salamat
    They also do ordinary cars there. Don't be overwhelmed by the expensive cars. Consider it a chance to have a close look at expensive cars being serviced.
How often should I put Power steering fluid on my reservoir?
