Results 1 to 7 of 7
    Sep 2014
    Question pag napipihit mo ba or na-twist ang puter tie rod end sa pamamagitan ng iyong kamay with less effort at all while reaching under the vehicle, ibig sabihin busted na din inner rack ball end?
    So palitin na ba ito pareho?
    And also even if right side lang ang maluwag, palitan na din ba other side. Since mag pa align din naman
    may locking mechanism po yang mga rods na yan, para hindi mapihit at ma-iba ang settings. yung iba ay may double nut, at yung iba naman ay may clamp. baka OK pa ang tie rods at kailangan lang na higpitan ang mga lock.
    the end is shot or needs replacement when, with the car jacked up, the tire can be rocked back and forth with the hands.
    When rocked at 9 and 3...
    not necessarilly. sometimes, the joints are so loose, one can feel and even hear it, even if the steering isn't locked, but positioned in the straight position.
    Feb 2009
    As i said before.. its cheap. When you do the toe adjustment, at least napalitan na both lep and right.
    Ginawa ko dati sa FX ko, dinala ko kay Zafra at sabihin mo gusto mong magpa-align pero meron kang napupuna, kaya isasalang nila ito para tingnan lahat bago i-align at sasabihin kung ano problema o papalitan muna.
    Libre naman yung check up, kaya ipinagawa ko sa suki kong mechanic, saka ako nagbalik sa kanila for alignment.
    Laking mura!
How to check tie rod if bad
