Results 1 to 10 of 19
October 17th, 2006 09:51 PM #1
after ma repair ang brakes ko because of the stuck up nung nabaha, nagkaron ng squeal parang eeek eeek eeek habang tumatakbo between 20-30kph, pag mas mabilis nawawala and kung mas mabagal dyan wala rin.However when i step on the brakes nawawala tunog.Madalas mangyari ito pag malamig ang preno, after some time driving nawawala ito ng kusa. sabi ng mekaniko ko ok lang naman daw dahil he checked and wala naman stuck up na. Kaso its irritating lalu na pag sa eskinita ka dumadaan dahil mas dinig ang squeak ng brakes. Ano kaya cause nito?
October 17th, 2006 10:01 PM #2
Brakes ba iyan? Hindi kaya bearing na contaminated?
October 17th, 2006 10:58 PM #3
even w/o stepping on the brakes may noise? possible ngang bearings... imho, kasi kung brake squeal yan, noise will come out only when you step on the brakes. normal yun kung medyo manipis na brake pads mo. meron talagang audible na squealing yan, which tells you your brake pads are worn out or starting to wore out.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 18th, 2006 01:00 AM #5
ang tunog nya kapareho ng brake linings pag worn out na, pero bagong palit ko lang brake pads sa harap. It goes away when i step on the brakes, pag bitaw preno eek eek eek na naman, usually lang naririnig ito at 20-30kph. Kala ko nung una naninikit na naman brake sa harap pero nung pina check ko sa mechanic wala naman daw stuck up. Di rin siguro bearings kasi at higher speeds than 30kph nawawala, kung bearings dapat bibilis ang tunog pag bumilis takbo.at lower than 20kph wala rin tunog. Nababaliw nako kakahanap kung ano dipresnsya hehehe
Toyota is my choice
- Aug 2005
- 2,063
October 18th, 2006 05:16 AM #7mag open windows ka.. tapos ron 20kph .. doon sa quite roads.. yan mahahanap mo talaga kung saan na wheel at anong sound like..
it could be bearing or brakes na clogged up sa potek.
October 18th, 2006 05:46 PM #8
October 19th, 2006 12:03 AM #9
I tried opening the windows ang galing yung sound sa front left wheel, weird thing is whenever lumalabas ang sound i try to step the brakes hard -well not that hard pero harder than usual, not enough to make the weels lock naman(i make sure no one was following hehehe), after that wala na. Pero balik uli ang sound after i park the car for some time and malamig ang brakes. Pag wheel bearing ba tumutunog lang for a certain speed?
Tsikot Member Rank 4
- 2,712
October 19th, 2006 12:27 AM #10try swapping the brake pads of the two front wheels ... this would eliminate if the pads are causing the noise ... if the noise transfers to the right front wheel then the pads are it
Hi reviving this thread. Ask lang mga sir if okay ba yung fiamm triple trumpet na horn? May...
What is your car's horn?
