Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Hi Guys,
    Need help. Meron kasing tumutunog kapag nagbebrakes ako. Parang "tukutok-tukutok" na sound - isipin nyo ung parang tunog sa roleta. Parang may tumatama, nawawala siya kapag bibitawan ko na ung brakes pero kung tumutunog na habang nakadiin ung brakes tapos kung lalong didiinan ung brakes, mas lalakas ung tunog nya. Ano po kaya ito?
    nangyayari siya kung bebreak ka minsan habang pababa ka or may lubak. Hindi regular ung occurence nya, minsan naeexperience minsan naman hindi. Help pls. TIA
    Harap o likod?
    All disk o hindi?
    Nov 2007
    As Gtootsie said, pls indicate where, front rear brakes? all disk or combination of disk and drum. This info will help us to figure it out the problem.
    Jun 2005
    sir, the problem there, i think, are the brake pads. they are already worn out or worn uneven that when you engage them and it locks on to the disk brakes, the caliper rattles again its brace causing the "tokotok" sound. had that same problem with my honda civic lxi front brakes.
    you can replace the brake pads to correct it or if the pads are still thick, you can have the discs re-faced. but if the sound is coming from the rear, which is drum brakes, again, replacement of the pads would be the solution.
    but better yet, have a mechanic from a good shop check it out to find out the exact solution.
    hope this helps..
    Kung galing sa front yung ingay, possible ngang brake pad or brake caliper. Pwede ding ball joint, nangyari na din ganito sa auto ko.
    Oct 2007
    Pasabay na rin po sa thread na ito.
    My civic front discs is making this whislting sound. Nakapagtataka kasi minsan-minsanlang sya mangyari. Also, if I suddenly push the brakes, walang tunog. pero pagdahandahan nandun nanaman sya. Tumutunog din sya pag galing ako sa full stop and dahan dahan akong nag aacelerate.
    What do you guys think? San ba pwedend ipadiagnose ito?
    Quote Originally Posted by JCBalunsat View Post
    baklasin mo sir tapos try mong i sand paper muna yung pads mo kung makapal pa sya.
    Oct 2007
    Quote Originally Posted by wrcastro_ph View Post
    Anong grit po need na sand paper? TIA
    Jun 2005
    sanding nga lan solution dyan sir kung makapal pa brake pads. use a sand paper na magaspang lang, wag yung pino. also, wag masyado sa pag sand paper, madaling maubos brake pads sa sand paper. we just want to remove the materials that causes the squeeking sound. pati na din disc brake, sand paper mo na din..
    but normally, that brake pads that are already worn out makes that sound to call the attention of the owner to replace it.
    Jan 2008
    kung hindi brake pads/brake shoe, baka scored na yung brake disc/rotor.
    Thanks po sa mga nagreply. Dinala ko po sa shop at medyo nawala ung tunog although meron pa ring tok sound kapag nagbebreak at kapag stop tapos magaaccelerate ay may parang tunog na parang merong iniistretch na bakal sa ilalim. Pinalitan ung caliper bolt, tie rods, disc pads, stabilizer link at engine support dahil medyo maingay na rin sa lubak.
    However, nung nilabas ko. Meron akong nararamdamang ingay sa ilalim sa bandang unahan. Parang merong something na maluwag sa ilalim na tunog bakal. Ano po kaya ito given na pinalitan na ung mga items sa unahan. Help po mga sirs at nakakalungkot lang dahil kala ko maaayos na pero iba naman ang problema. Medyo newbie lang ako sa pagkokotse kaya takot ako kaya kunsulta muna ako sa inyo.
    May 2004
    Baka naman maluwag yong pads at may konting movement yong pads twing magbe-brake ka. Isa to sa common problem ng mga Lexus IS, may clicking sound twing nagbe-brake. Try mo rin na lagyan ng anti-squeal paste yong likod ng brake pads.
    Oct 2007
    Quote Originally Posted by yourman View Post
    hehe di ko pa nagagawa yung liha kasi di ko lam kung anong liha gagamitin ko. ano ba dapat?
    Sep 2006
    saken paatras lang maingay... sa harap galing
    baka sir CV joints, nasilip na ba to?
    Quote Originally Posted by stolen*soul View Post
    sir nakita na ung prob. maluwag lang ung stab links. not sure lang if sinadyang iwan or honest mistake. pinasikipan ko na, aun oks na. thanks sa reply
    Dec 2007
    Hi Guys,
    tol
    check mo if step on mo ang brake pedal eh parang bumabalik ba?
    if bumabalik parehas tayo ng sira, pinalitan yung rotor assembly kasama na yung bearing at yung 4 stud P850 lang yun sa satoshi at labor P500 ata mahirap kasi magbaklas nun eh
    much better pa lifter mo ang kotse at patakbuhin pra umiikot ang tires dun nila makikita yun
    Would dismantiling front brake & removing pads a DIY thing?..I'm daring to do so kasi may squeaking sound din yung brake (still new) ng revo ko sa front right side...FYI, I had already tried replacing the rear drum brakes of my car before at ok naman...same lang ba yung effort in dismantling front & rear brake assemblies?...
    Nov 2003
    if there is noise after work you should bring it back to whomever fixed it so they can recheck the work they did.
    Apr 2008
    Pls help me also. I have a 97 VTI and everytime I brake may noise din. I brought it to several repair shops na din like servitek, rapide, etc but hindi nila maalis yung noise. They checked the caliper pins, brake pads, disc, etc ok naman daw lahat. Yung noise is parang may loose na screw everytime I brake. Is there a shop in alabang or paranaque area na brakes specialist that you can recommend?
Need Help: Noise in Braking
