Results 1 to 20 of 32
    Oct 2007
    I just want to ask how much will it cost me if I change the rotor discs to slotted ones?
    Also, what are the brands that you would recommend for both the rotor discs and brake pads?
    Ride: Civic 96 Vti
    The reason I want to do this is that I've heard that it can reduce the noise when braking as well as better braking power. I've had it with the whistling sound (which I cannot find by the way).
    Call speedlab for a quote... there's a slotted disc lying around there yesterday... hehe.
    http://www.speedlab.com.ph/
    Oct 2007
    Quote Originally Posted by mazdamazda View Post
    By the looks of their website, I think they're pricey. Are they?
    Slotted rotor discs & performance brake bads are not cheap.
    but, what would be a good brand for brake pads? except for the OeM ones, I also, need to change my pads, thanks..
    Why change rotor discs when you are not into racing. Original brake pads are not always the best as I have found out in my pajero. Try bendix pads but make sure your rotors are trued first before installing new pads.
    If you feel that you want to change to slotted rotors because it looks good its your call. You can improve your brakes by just changing pads, fluid to dot 4 or 5 and stainless steel braided lines.
    Oct 2007
    Quote Originally Posted by Si 06 View Post
    I have bendix already. I think it's the culprit of the noise that I'm talking about. The noise is like someone whistling a hymn or something. I'm not changing the brakes to improve my cars looks. I'm just looking for good braking power.
    What do you mean that the rotors are trued? Really can't get it. Sorry.
    AFAIK, i have dot 5 for the brake fluid.
    As for the stainless braided lines, I'm not sure about that either.
    Q: How much for the steel braided lines and what are they? TIA.
    Jul 2006
    RE: DOT 5 do not ever make the mistake of mixing this with DOT 3 or 4. DOT 5 is very different than the other two.
    If you want good braking power, do you think your car's braking performance has diminished? Does it take more effort to step on the brake?
Slotted Discs and good replacement brake pads
