To be exact, 1 year na problem ko sa Toyota Lovelife ko about sapower steering nya, kung hindi tagas, meron ugong, kung walang ugong , meron naman tunog kapag sinasagad left and right..
HISTORY:
JUNE 23,2009 = mauugong yung manubela kapag nililiko, so ang ginawa ko, palit ng hose..nawala naman sya = expenses = 1,900 petot
SEPTEMBER 2009 = Tumagas naman oil sa hose and rock pinion, overhaul daw kailangan. nawala yung tagas , expenses = 5,000 pesos
NOVEMBER 2009 = Nagkatagas naman yung power steering pump, sabi over haul uli, so pina over haul ko uli..nawala yung tagas ,expenses = 3,000 pesos
DECEMBER 2009 = May tagas uli, binalik ko uli ,sablay yung overhaul, palit uli ng oil seal, expenses = 900 petot
FEBRUARY 2010 = may tagas uli, hirap iliko, ang sabi baka sa pump daw, pina overhaul ko uli, pero sa ibang mekaniko na = expenses = 3,000 petot
KAHAPON 2010 = May tagas uli, pina over haul uli, ok na nawala yung tagas,,kaya lang may tunog naman kapag sinasagad kaliwat kanan..huhuhu = expenses = 3000 petot uli
may problem din ako sa PW sa may bandang pasig sa shaw meron ako trusted na mechanic sa shaw blvd ROBUST - Bridgestone yung place
ang option nya sakin
1. replace repair kit - orig part with electroplating 6500
2. replace repair kit - orig part with electroplating 9500
3. refurbished/recondition rack and pinion - 15k
sa dami ng ni repair nya di na advisable talaga yung repair kapag may tama na so i had to pick the (3) sa long run nya tinignan
magaling yung shop na ito - explain nya lahat and he will give his honest opinion about your problem para di mag paulit ulit yung gawa mo...
