Results 1 to 10 of 10
    Feb 2006
    Mga guru need your opinions:
    Car is a gen1 crv a/t
    Pag naka idle ako, matigas ang steering and tumutunog ang p/s pump. Parang moaning sound. Pero pag ni rev ko lumalambot ang steering and medyo nawawala yung tunog. Ano kaya problema nito? Barado kaya ang pump? Is the pump repairable or kailangan na palitan yung pump? Meron bang power steering filter?
    Thanks in advance
    Dec 2002
    have you checked your p/s fluid baka kulang or your p/s belt is loose.
    Did you check if you have the correct level/requirement of PS fluid?
    Feb 2006
    Quote Originally Posted by johnart
    p/s fluid is in the max level. also tightened the belt yesterday pero ganun pa rin.
    Dec 2002
    are you using your stock tires or did you change them ?
    Feb 2006
    yes it's stock 205/70/15
    Aug 2005
    Ps fluid check mo..
    tire pressure check mo..
    belt check mo din..
    PS pump check din..
    check mo un pressure hose kung walang leak. p/s fluid nag dedeteriorate din overtime, try mo drain and replace with fresh fluid
    Dec 2002
    whats the mileage of your crv ?
    Nov 2003
    it's prob the power steering high pressure hose causing the noise.
Help - Power Steering Problem
