Results 1 to 10 of 10
- Mar 2006
- 106
June 3rd, 2009 08:46 AM #1Hi guys,
Nagpa-change oil ako ng liteace and sabi sa ken ng servitek busted na daw ang wheel bearings. They quoted me around 10K to replace the bearing-
San ba okay bumili ng wheel bearings na original/high quality and magkano ba ito dapat? Hindi muna ako bumili kasi di ko alam ano bang tamang presyo ng part na yan.
Thank you po sa tulong
June 3rd, 2009 05:31 PM #2
original? ganyan talaga presyo nyan.
bili ka na lang replacement bearings. tatagal din naman yun.
June 6th, 2009 06:21 AM #4
gotcha,
there used to be manila bearing center and i don't know if they are still around. what you need to do is get the bearing number and get an exact replacement, it will have the same dimensions, shape, number of rollers and in all the same architecture. the roller cage and rollers has to be replaced with the matching outer bearing cup. they are matched at the factory. if they were non drive wheel bearings, the labor time is around 40 minutes per side or one hour and 20 minutes for the whole axle. remember to replace the grease retainer( some people call it oil seal) with it. do not overtorque. the most common procedure for cars is after having the cup seated in the hub, and the bearing cone is prelubricated, is to torque the spindle nut to 80 foot pounds and back off, then tighten by hand using a slip joint pliers. secure the adjustment with a cotter pin or with a new nut with nylon locking insert or peening the nut if there is provision for peening it.
jick
certified auto
guam
- 168
June 8th, 2009 03:47 PM #610k for bearings is total BS. tawag ka sa united bearing sa binondo 244-7737 distributor sila.
http://www.unitedbearing.com/
June 9th, 2009 12:05 AM #7
the best way para makatipid is ikaw na lang bumili ng bearing, bring the sample or get the number code para sakto din ang makukuha mong parts. bring it to your trusted shop, ang labor sa shop na pinagawan ko before ay 250 per wheel
June 9th, 2009 09:59 AM #8
+1 sa suggestion ni sir Esnie, I also think this is the best way to go.
just recently had the suspension of my rig checked and quoted, one of the things to be replaced DAW is the wheel bearings, I will post the price and labor as soon as I find that piece of paper
June 13th, 2009 11:46 PM #9
Update on that price and labor cost I promised:
Cruven is charging 950/pc (OEM yata) wheel bearing
and labor for upper wheel bearings is 600 and another 600 for the lower
a shop here in fairview is asking for 600/pc (replacement no idea of the brand) wheel bearing and a total labor cost of 1000.
will still be asking around for better prices so if you guys have any idea where to get a better deal please chime in.
June 15th, 2009 12:23 PM #10
if you can get the bearing numbers better ikaw na lang bumili, ako ganun ginagawa ko, to get the part number tapos ako na nabili, you can choose from different brands of bearings (timken, skf, ntn, fag, etc...)and dun ka na din bibili ng oil seals (NOK brands). Kahit original pa yan galing casa di naman sila ang nagawa ng parts na yun eh at mahal pa. Gawin mong practice to source out the parts from shops in manila mas makakamura ka talaga, from bearings, oils eals, bulbs, shocks at madami pa.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
